AUDIOTRAK Prodigy Cube USB / DAC / PREAMP 24 / 96khz
This small multifunction converter offers a very good level headphone amplifier, a pre-amplified analog output and also serves as a digital interface.
Based on a universally recognized USB interface component (TE7022L) that allows easy installation on all systems, it is also equipped with an aop on support allowing an easy change.
The design is based on "Audiophile" components (Sanyo OS-CON, SamYoung LXV, AHS and Wima capacitors).
Comes with a USB cable and a stereo RCA / RCA cable.
Features: Strong>
Analog Output | Line Out (RCA), Dual Headphone Out (6.35 and 3.5mm) |
Analog Input Span> | Microphone input (3.5mm, 24bit / 48Hz) Span> |
Digital Output |
Output Method Span> | PCM, AC3 PassThrough |
Dynamic range | 108dB |
Interface | Interface USB (1.1 / 2.0 compatible) |
aop | OPA 2134 x 1 (Socket-type) THD + N: 0.00008% (Max) (2kΩ @ 1KHz) Span> |
DAC | Wolfson WM8776 |
Supported impedance | 16 ~ 150Ω Span> |
Sampling rate Span> | 24bit / 96kHz |
Food | Powered by USB port Span> |
Operating Systems Span> | Windows 8, Windows 7, Windows Vista, Windows XP, Mac OS X |
Dimensions (mm) | 94 X 90 X 22 (W x D x H) |
Div>
- Headphone output: (1/4 "stereo jack) for high impedance headphones
- Output casque: (3.5 mm stereo jack) for low impedance headphones.
- Microphone input: (jack 3.5mm mono)
The high-sensitivity microphone amp is used to record the voice and is completely separated from the analog output port to avoid any interference between the input and output of the sound. - Output Selector: The headphone output is selected by default, the line output is switched off by simply pressing the output selector.
- Volume control: Controls both the headphone output level and the line output.
- Status LED (green): Green indicates that the Prodigy is turned on. Li>
- USB LED (yellow): The yellow LED indicates that your computer recognizes the Prodigy as a device
- Analog Stereo RCA Output
- USB Connector
- Digital output (optical / coaxial) Li>
P>
P>
P>
P>
P>
P>
P>
P>
P>
