HA INFO DA1 DAC Headphone Amplifier 24Bit / 192khz - TE7022
50%
3.5 / 5
Reduced price!
Reference : 7026
Limited special offer
149,00 €tax incl.
-50%
74,50 €tax incl.
62,08 € tax excl.
HA INFO DA1 - DAC / Headphone Amplifier 24Bit / 192khz - TE7022
This new DA1 is a digital headphone amplifier with a USB input.
Equipped with an Alps potentiometer, ELNA capacitors, and a DAC WM8805 delivers a rich, warm and detailed sound.
The Jack 6.35 output allows you to connect a headphone from 30 to 600 ohms.
The stereo RCA output is fixed level.
Features:/ Strong>
  • TENOR 7022 conversion chip (24Bit -96kHz)
  • Plug n Play: XP, Windows 7, Mac OS, LINUX ... (ASIO supported)
  • Inputs: Coaxial and optical and USB
  • Digital Output: Coaxial and Optical (Passtrough)
  • Sampling rate: USB (24Bit 32K ~ 96K), SPDIF (24Bit 32K ~ 192K)
  • Analog output: Line-Out (2V RMS)
  • Headphone output: 5V RMS
  • Power Supply: DC18V Voltage
  • Dimensions: 180mm x 112mm x 48mm
  • Weight: 500 G
  • Packing: power supply transformer
  • Color: Black (Silver Front)
https://www.audiophonics.fr/images2/7026/7026_HAINFO_DA1_1.jpg
https://www.audiophonics.fr/images2/7026/7026_HAINFO_DA1_2.jpg
https://www.audiophonics.fr/images2/7026/7026_HAINFO_DA1_3.jpg
https://www.audiophonics.fr/images2/7026/7026_HAINFO_DA1_4.jpg
OutputJack 6.35mm
OutputOptical Toslink
OutputCoaxial SPDIF
DAC / ADC ChipTenor 7022
Max sampling rate192kHz
ColorSilver
2 reviews
Chauffe beaucoup trop
Fonctionne normalement mais la température de l'appareil est vraiment exessive.
This review has been posted for HA INFO DA1 DAC Headphone Amplifier 24Bit / 192khz - TE7022
HA INFO DA1 review
Gets very hot. Not for non-stop operation. Caps are 85 degrees and it gets above that inside the case after half an hour or so. Very strange power supply arrangement. DC feed is 18 volts and a floating earth is obtained by usage of a power amp (TDA2030) providing a floating earth on its output. This chip is on a rather large cooler but still gets extremely hot.
Sound quality: There is a distinct ringing in the high mid / low treble area. Otherwise ok. But the ringing "s"-sounds, etc, are exhausting.
