MATRIX AD1955 Mini-i DAC (Version 2011)
DAC with USB inputs - BNC (SPDIF) - Toslink - AES / EBU
RCA - XLR Variable Outputs - Headphone Amplifier + Remote Control Aluminum
This unit is a Digital - Analog Preamplifier XLR and Headphone Amplifier.
Despite its average size it is equipped with all existing digital inputs, two types of analog outputs, a headphone amplifier.
It even has an SPDIF output to convert the signal to the digital inputs.
This may be useful, for example, for a DTS or AC3 signal arriving in optics and needing to be decoded externally by a DTS decoder.
The XLR and RCA outputs are variable through the volume knob which is an endless potentiometer. (-90dB to -0dB)
The sound level is recorded when turned off, so this unit can really be used as a digital preamp and placed at the top of your Hi-Fi system.
The inputs are selected by pressing the same button.
The decoder scheme is symmetrical, it uses two converters based on the AD1955 Analog Device already used on very high-end devices.
Thee receiver is an AK4113 with low Jitter and chip amplification headphone TPA6120.
Features:/ Span>
- Diagram100% symmetrical
- Decoding chips 2x AD1955
- Up to 24Bit / 192kHz
- Receiving chip AK4113 low jitter
- Integrated headphone amplifier, up to 300ohm
- Outputs XLR and RCA audiophile quality variables
- Allows to be used as preamp or simple DAC (without volume control)
- Comes with Infrared Control Remote Control (Volume Control, Mute, Power On / Off and Source Selection)
Digital Inputs:
- Toslink optics from 44.1 to 192kHz
- Coaxial: 75ohm RCA or BNC (supplied adapter) from 44.1 to 192kHz
- AES / EBU: XLR symmetrical 5v from 44.1 to 192kHz
- USB: 44.1 or 48kHz USB-B connector (PC only)
Digital Outputs:
- SPDIF Coaxial
- 44 to 192kHz according to input
- Allows even redirecting an AC3 or DTS stream
Analog Outputs:
- RCA: 0 ~ 2V variable volume
- XLR: 0 ~ 4V variable volume
- Frequency response: 20Hz - 20kHz
- Signal to noise ratio: 105dB
- Dynamic range: 108dB
- Distortion: 0.0002% @ 1kHz
Others:
- Weight: 1.2kg
- Dimensions: 205x155x48mm
- Power Consumption: 15W
- Supplied with: Power cable, B adapterNC -> RCA3
</ P>
</ P>
Internal view:
</ P>
Digital inputs:
Pair of AD1955 converters:
