MYTEK BROOKLYN DAC+ ES9028PRO DAC Headphone Amplifier Phono Preamplifier 32bit 384kHz DSD256 MQA
The Mytek Brooklyn DAC+ is an audiophile digital-to-analog converter compatible with a multitude of high-resolution audio formats. It supports PCM streams up to 32bit 384kHz, DSD up to DSD256 but also MQA. Particularly versatile, the Brooklyn DAC+ is also a phono preamplifier and headphone amplifier.
By buying this product you get 199 loyalty points
Reference : 14849
1 999,00 €tax incl.
1 665,83 € tax excl.
Mytek Brooklyn DAC+
ES9028PRO DAC Headphone Amplifier Phono Preamplifier 32bit 384kHz DSD256 MQAMytek Brooklyn DAC+ DAC ES9028PRO Amplificateur Casque Préamplificateur Phono MM/MC 32bit 384kHz DSD256 MQA
Its numerous inputs allow the connection of the vast majority of HiFi devices. We can find USB-B, Coaxial SPDIF, Toslink Optics and AES/EBU. On the output side, the device offers unbalanced RCA, balanced XLR but also two headphone outputs amplified on 6.35mm jack, capable of delivering a consequent power of 6W.
The Brooklyn DAC+ is an ideal choice for integration into a high-end audio system, providing incredibly accurate, rich, and dynamic sound reproduction, thanks to its well-designed circuitry.
A high-performance conversion stage
The conversion stage of the Brooklyn DAC+ is based on an ESS Sabre 9028Pro chip, known and recognized by audiophiles for its audio performance. It provides perfect support for the vast majority of high-resolution file formats such as DSD, DXD, MQA and PCM up to 32bit 384kHz. Renowned for its precision, low noise and high dynamic range, this DAC will help you get the most out of your music. It is here associated with an extremely precise clock generator to obtain a very low jitter of 0.82ps. When the Brooklyn Bridge is used in USB with a computer, its DAC is coupled to an NXP controller, ensuring an incredibly accurate digital to analog conversion.
Integrated phono preamplifier
In addition to its DAC function, the Mytek Brooklyn DAC+ also includes a phono preamplification stage. This uses a specifically selected transformer associated with a relay to select the input level. The device is therefore compatible with turntables with MM (Moving Magnet) or MC (Moving Coil) cells.
This phono preamplifier can also be turned off, in order to use a preamplified vinyl turntable or any other HiFi device, such as a CD player.
Powerful headphone amplifier
Also benefiting from two headphone outputs in Jack 6.35mm format, the Brooklyn DAC+ will also allow you to enjoy a very high quality headphone listening. Its impedance of 0Ω and its important power of 6W allows it to efficiently accompany the great majority of headphones and earphones, including the most demanding models. This dual headphone output can also be switched to a balanced output.
Product typeDAC
Preamplifier / Phono preamplifier
Headphone amplifier
DAC ChipES9028Pro
Inputs1x USB-B : PCM up to 384kHz, DSD up to DSD128 / DoP
1x AES/EBU : PCM up to 192kHz, DSD up to DSD64 DoP
2x SPDIF Coaxial : PCM up to 24bit 192kHz, DSD up to DSD64 DoP
1x Optical Toslink / ADAT : PCM up to 192kHz, DSD up to DSD64 DoP
2x SPDIF3 DSD : DSD up to DSD256
1x Stereo RCA
1x WCK input
Phono GND terminal
1x Balanced stereo XLR
2x Jack 6.35mm headphone output
1x WCK output
DSD up to DSD256
DXD
MQA Support
Dynamic range130dB
ClockMytek Femtoclock Generator™
0.82ps
Headphone amplifier power6W
Analog attenuator1dB step
Independent main and headphone output volume
Digital attenuator32bit
1dB step
Relay bypass
Analog preamplifierLine level
Phono MM / MC
Relay control
Audio interface functionAll digital inputs can be routed to a computer via USB
Power supply100-240VAC 50-60Hz
Optional DC / battery power input
Dimensions216 x 216 x 44mm
Weight2kg
Package1x Mytek Brooklyn DAC+
1x Remote control
InputAES/EBU
OutputJack 6.35mm
Remote ControlYes
The Mytek Brooklyn DAC+ is an audiophile digital-to-analog converter compatible with a multitude of high-resolution audio formats. It supports PCM...
