NUFORCE ICON uDAC2 HP - DAC 24/96 and Headphone Amplifier
Reference : 5483
115,00 €tax incl.
95,83 € tax excl.
The NuForce uDAC2-HP DAC has been designed to deliver a superb headset experience from your personal computer.
heallows you to play your songs in high quality directly via USB thanks to this external decoder 24bit / 96kHz.
The double mechanical correction of the electric phase shift of the digital signal (jitter) as well as the use of a new TOCOS potentiometer (more precise and progressive favors the perfect listening at low volume.
You will understand that NuForce uDAC2-HP is capable of restoring a musical quality that is not commensurate with its size, it will quickly become for you the perfect gateway between your microcomputer and your headphones.
Features:/ P>
  • Double jitter reduction and oversampling
  • No condenser on any of the audio signals
  • USB powered, no need for adapter
  • All headphones with an impedance between 16 ohm and 300 ohm are compatible with the uDAC2-HP Icon
Specifications:
  • Input
    • USB DAC: USB 1.1, 2.0 compatible. native sampling: 32, 44.1, 48, 96kHz
    • Maximum sampling rate: 96kHz
    • Resolution: 24-bits
  • Analog Output on Jack 3.5 Stereo
    • Power output: 80mW x 2 @ 16-Ohm
    • THD + N 0.05%
  • USB powered
  • Dimensions(W x H x D): 68 x 38 x 21 mm
OutputJack 3.5mm
Max sampling rate96kHz
