Schiit MODI 2 UBER DAC USB 2.0 24bit/192kHz CM6631A AKM AK4396
Reference : 9388
240,00 €tax incl.
200,00 € tax excl.
Schiit MODI 2 UBER DAC USB 2.0 24bit / 192kHz CM6631A AKM AK4396
This USB DAC is the latest and most successful DAC in the MODI range.
The MODI 2 UBER is designed around a C-Media CM6631A USB interface associated with AKM4396 converter. A dreadfully effective couple for your audio system.
The MODI 2 UBER connects to any Windows or Mac computer and requires no driver to develop its full potential at 24bit / 192kHz sampling rates.
It is equipped with an asynchronous transfer mode with individual quartz for frequencies of 44.1 and 48kHz.
Characteristics:
  • Sampling rate: 16bit / 44.1kHz, 24bit / 88.2kHz to 24bit / 192kHz via Optical Toslink and Coaxial SPDIF
  • C-Media CM6631A USB 2.0 Interface
  • SPDIF Interface AKM AK4113
  • Converter: AKM AK4396
  • Filtering: Analog Devices AD8616
  • Digital inputs: USB 2.0, Optical Toslink, Coaxial SPDIF
  • Analog RCA output
  • Frequency response: 20Hz-20kHz to 0.1db
  • Output level max. : 1.5Vrms
  • THD: <0.002%, 20Hz-20kHz, 1.5Vrms
  • IMD: <0.003%, CCIR
  • Signal-to-noise ratio:> 104db, unweighted, compared to 1.5Vrms
  • Crosstalk: -80dB, 20Hz-20kHz
  • Output impedance: 75 ohms
  • Power supply 16V AC included
  • USB 2.0 cable: not included
  • Dimensions: 127x89x31mm
  • Weight: 460g
[Img-8754-left-thickbox_default]
Schiit MODI 2 UBER
Schiit MODI 2 UBER
Schiit MODI 2 UBER
Input
  • USB
