SMSL TV-DAC2 USB Audio converter OTG ANDROID to stereo analogue Jack 3.5mm
This dedicated ANDROID USB DAC brings audio quality to any flat screen with built-in Android OS. It allows you to add a stereo output in 3.5mm jack format on all ANDROID TVs.
Reference : 12491
20,90 €tax incl.
17,42 € tax excl.
-SMSL TV-DAC2-
ANDROID TV Converter USB to Analog 3.5mm Stereo Jack 3.5mm Stereo TV Converter
A DAC plug and play for your ANDROID TV
This ANDROID-compatible USB DAC allows you to add a stereo analog output to any USB TV port with ANDROID support. It provides superior sound quality for attacking a pair of speakers or a classic analog Hifi amplifier. It is only compatible with ANDROID OTG and ANDROID computer USB AUDIO class 2.0.
Warning: This DAC has no headphone output.
Technical features
Digital inputUSB TYPE A
analog Outputjack 3.5mm stéreo
Indicator powerLED
Silence noise ratio94dB
Output level650mV
Dynamic95dB
 harmonic distorsion level0.006%
CompatibleANDROID OS OTG, Windows et macOS
Various
Power5V DC 500mA via USB-A (longueur : 20cm)
Dimensions48 x 15.8 x 6mm
Weight9g
Box typealuminium
OutputJack 3.5mm
Max sampling rate768kHz
Max sampling rateDSD512
This dedicated ANDROID USB DAC brings audio quality to any flat screen with built-in Android OS. It allows you to add a stereo output in 3.5mm jack...
