TOPPING D50 III DAC Black
Topping's new D50 III desktop DAC has been updated to deliver even better performance than its predecessors. It now features two ES9039Q2M DAC chips and an XMOS XU-316 USB interface, enabling it to support high-resolution streams up to PCM 32bit 768kHz and DSD512.
By buying this product you get 22 loyalty points
Reference : 19011
229,00 €tax incl.
190,83 € tax excl.
Shipping date: 22-04-2025.
Topping D50 III DAC 2x ES9039Q2M XMOS XU316 Bluetooth 5.1 LDAC 32bit 768kHz DSD512 Black
TOPPING D50 III picture
Topping's new D50 III desktop DAC has been updated to deliver even better performance than its predecessors. It now features two ES9039Q2M DAC chips and an XMOS XU-316 USB interface, enabling it to support high-resolution streams up to PCM 32bit 768kHz and DSD512. It also features a latest-generation Qualcomm QCC5125 Bluetooth chip for superior wireless reception. It supports Bluetooth aptX, aptX Adaptative, aptX HD and LDAC codecs. Topping chose to offer the possibility of operating it as a DAC/preamplifier with volume control, coupled with active speakers or a power amplifier. The DAC D50 III's connectivity interface features numerous digital inputs: SPDIF Coaxial, Toslin Optical and USB-C. Outputs include a balanced 6.35mm TRS jack and an RCA output. Last but not least, an attractive display, Bluetooth remote control and 10-band equalization software enhance the user experience.
Topping D50 III: two ES9039Q2M DAC chips and XMOS XU316 USB interface
The D50 III features one ES9039Q2M digital-to-analog converter chip per channel for balanced signal processing. These two DAC chips, combined with the XMOS XU316 USB interface, enable Topping's D50 III to support high-resolution streams up to PCM 32bit 768kHz and DSD512. The USB XMOS XU 316 interface is accompanied by a Thesycon driver for plug-and-play operation and a high level of compatibility. The I/V conversion stage has also been enhanced to maximize the performance of the ES9039Q3M DAC chips. Compared with the D50 S, the D50 III's chipset achieves better SNR, dynamic range and distortion.
Photo of TOPPING D50 III DAC ES9039Q2M chipset
TOPPING D50 III Bluetooth 5.1 features
Topping D50 III: Bluetooth 5.1
A QCC5125 Bluetooth receiver chip enables the D50 III DAC to support the high-resolution codecs SBC, AAC, aptX, aptX Adaptative, aptX HD and LDAC. As a result, you can enjoy high-quality wireless transmission at up to 24bit 96kHz, a higher resolution than the CD standard.
Topping D50 III: preamplifier mode and high output power
The D50 III's output level is adjustable. It features a 4Vrms level on its balanced output and 2Vrms on its RCA output, which can be increased to 5Vrms on its 6.35mm TRS output and 2.5Vrms on its RCA output. In addition, a preamplifier mode lets you use the D50 III DAC with active speakers or a desktop amplifier.
TOPPING D50 III in preamplifier mode
Photo of the TOPPING D50 III USB-C connectors
Topping D50 III: USB-C interface
The Topping D50 III's USB-C interface has two ports. A transmission port and a power port. It is recommended to use the additional power port when the D50 III is connected to a laptop or phone.
Topping D50 III: Bluetooth remote control and 12V trigger
A Bluetooth-enabled remote control is supplied with the D50 III. This allows the device to be controlled remotely for greater ease of use. There's also a 12V trigger on a 3.5mm jack, enabling you to switch several devices on or off simultaneously. This function is very practical if you use the D50 III in combination with the brand's A50 III headphone amplifier, for example.
Photo of TOPPING D50 III's remote control and 12V trigger connectors
Topping D50 III: 10-band equalizer
Topping has developed a 10-band equalizer offering the possibility of adjusting numerous settings. The software supports the import of target curves and the saving of multiple profiles for quick changes.
The PEQ function supports up to 32bit 192kHz and is only available via the USB-C port.
TOPPING D50 III EQ software
Topping D50 III overview
TOPPING D50 III connectors overview
1Balanced stereo output 6.35mm TRS jack
2RCA stereo output
3SPDIF coaxial input
4Toslink optical input
5Bluetooth antenna
612V Trigger
7USB-C input
8USB-C power port
Product typeDAC
DAC chips2x ES9039Q2M
USB interfaceXMOS XU316
Bluetooth chipQCC5125 (Bluetooth 5.1)
Inputs1x USB-C
1x SPDIF Coaxial
1x Optical Toslink
Bluetooth
Outputs1x RCA stereo output
1x Stereo balanced 6.35mm jack output
Supported sample ratesUp to PCM 32bit 768kHz and DSD Native up to DSD512
Supported Bluetooth codecsSBC, AAC, aptX, aptX adaptative, aptX HD, LDAC
EQ adjustment
12V trigger
Remote control
RCA LINE OUTPUT MEASUREMENTS
THD+N @ 1kHz (A-Wt)< 0.00008%
THD @ 20Hz-20kHz (90kBW)< 0.0004%
SNR (@ Max. output 1kHz, A wt)127dB @ 1kHz
Dynamic range127dB @ 1kHz
Frequency response20Hz-20kHz (±0.1dB)
20Hz-40kHz (±0.3dB)
Output level2.0Vrms @0dBFS (4V mode)
2.5Vrms @0dBFS (5V mode)
Noise level (A-wt)< 1.1uVrms
Channel crosstalk-136dB @ 1kHz
Channel balance0.3dB
Output impedance50Ω
6.35MM JACK BALANCED LINE OUTPUT MEASUREMENTS
THD+N @ 1kHz (A-Wt)< 0.00006%
THD @ 20Hz-20kHz (90kBW)< 0.0002%
SNR (@ Max. output 1kHz, A wt)132dB @ 1kHz
Dynamic range132dB @ 1kHz
20Hz-40kHz (±0.3dB)
Output level4.0Vrms @0dBFS (4V mode)
5.0Vrms @0dBFS (5V mode)
Noise level (A-wt)< 1.3uVrms
Channel crosstalk-147dB @ 1kHz
Output impedance100Ω
Power supply5V DC via USB-C
Dimensions125 x 131 x 45mm
Package1x DAC Topping D50 III
1x USB-A to USB-C cable
1x USB-C to USB-C cable
1x Bluetooth antenna
1x Bluetooth remote control
OutputJack 6.35mm
DAC / ADC ChipES9039Q2M
Max sampling rateDSD512
Max sampling rate768kHz
Remote ControlYes
2 reviews
Parfait
Acheté pour alimenter un ampli casque Lake People. Il remplit parfaitement son rôle, le son est neutre, transparent et plein d'énergie. La fonction EQ est idéal pour égaliser un casque.
En points négatifs : alimentation non fournie et l'application pour le paramétrage de l'égaliseur n'est disponible que sur PC.
This review has been posted for TOPPING D50 III DAC 2x ES9039Q2M XMOS XU316 Bluetooth 5.1 LDAC 32bit 768kHz DSD512 Black
Has DAC mode and pre-mode
Great DAC (look at audioscience review of it).
Has a DAC mode (to ensure max volume if you have a source managing audio level). Which is what I needed.
Topping's new D50 III desktop DAC has been updated to deliver even better performance than its predecessors. It now features two ES9039Q2M DAC...
