SOMMERCABLE CONTROL FLEX Multiconductor Cable 3x0.75mm² Ø 6.5mm
Reference : 9864
1,60 €tax incl.
1,33 € tax excl.
flexible, overall copper braid, electromagnetic compatibility according to DIN 47100, self-extinguishing and anti-flammable according to IEC20-22II (mode B)
SOMMER CABLE - SC-CONTROL FLEX
Trust is good, but "Control" is better ...
We deliver a robust yet very flexible cable for use as a control and signaling conductor for automation devices (eg RS232 or RS422) or computer systems. The special envelope is anti-flammable and self-extinguishing according to VDE 0472, part 804, mode B.
The CONTROL FLEX is protected by copper braid shielding (optical coverage> 90%), which makes it particularly suitable for problematic use of EMV.
Please note qwe produce this cable for wholesalers and for OEM customers and that it is - at least in part - printed with the names prescribed by the DIN standard or by other approvals, without the SOMMER CABLE logo.
ADVANTAGES:
  • Mobile, flexible up to a temperature of -10 ° C (fixed installation down to -30 ° C)Practically resistant to oils
  • Self-extinguishing and anti-flammable according to VDE 0472, part 804, mode B
  • Easy to work
USE:
  • Fixed installation of the building
  • Signal and automation driver
  • Retransmission of RS232 and RS422 standards
  • Loudspeaker cable in ELA technique
Specifications:
ConstitutionLIY-CY
Envelope, diameter6.50 mm
Conductor inside3 x 0.75 mm 2
Copper strands per coreaccording to DIN VDE 0295 mm
Insulation of the conductorPVC / FRNC according to DIN VDE0207 part 4
Protectioncopper braid, tinned
Optical cover90%
Operating temperatureFixed installations min. -30 ° C
Operating temperaturemobile min. -20 ° C
Operating temperatureFixed installations max. 80 ° C
Operating temperatureMobile phone 70 ° C
Color of envelopegray (RAL 7001)
Packaging unit, packing unitper meter
Electrical Specifications:
Capacity metric cond./cond.120 pFMetric Capacity Screen / Display240 pFOdometer Resistance, Conductor<165 OhmResistance, insulation> 20 MOhmInductance per 1 km0.65 MHzOperating voltageOperating voltageTest voltagefor 50 Hz (Cond./Cond.) 1200 VTest voltagefor 50 Hz (cond./screen) 800 V
Length (m)Sold by length
Number of conductors3
Section (mm²)0.75
