CANARE RJC6-4P-SFM Ethernet Cable Cat 6 SF/UTP 8x0.26mm² Ø8.6mm
This Cat 6 Canare RJC6-4P-SFM Ethernet cable integrates 4 pairs of twisted 0.26mm² conductors with double general shielding type SF/UTP. The latter is composed of a strap and a braid which considerably limits the impact of interference on the signal.
Reference : 14371
4,90 €tax incl.
4,08 € tax excl.
Shipping date: 22-04-2025.
Canare
Canare RJC6-4P-SFM
Canare RJC6-4P-SFM Câble Ethernet Cat 6 SF/UTP 8x0.26mm² Ø8.6mm
This Cat 6 Canare RJC6-4P-SFM Ethernet cable integrates 4 pairs of twisted 0.26mm² conductors with double general shielding type SF/UTP. The latter is composed of a strap and a braid which considerably limits the impact of interference on the signal. This cable sold by the meter will allow you to design quality network cables, both robust and efficient.
Product typeEthernet cable
Ethernet standardCat 6
Cable diameterØ8.6mm
Conductors section8x0.26mm² (23AWG) - Solid-conductor for fixed installation
Cable shieldingType : SF/UTP
Aluminium Foil + Braid
Conductor quantity per mm1/0.57A
DCR8.2Ω / 100m
Impedance100Ω
Insertion loss at 100MHz19.8dB / 100m
Insertion loss at 250MHz32.8dB / 100m
External sheath materialPVC
Weight / 100m8.9kg
Cable colorBlack
QuantityCable sold by the meter
Diameter (mm)8.6
Length (m)Sold by length
Number of conductors8
Insulation materialNC
ShieldingYes
Section (mm²)0.26
Ground / ShieldingYes
This Cat 6 Canare RJC6-4P-SFM Ethernet cable integrates 4 pairs of twisted 0.26mm² conductors with double general shielding type SF/UTP....
