SOMMERCABLE CLASSIC MKII RG316/U FEP Audio / Video Cable 50 Ohm Ø 2.5mm
Reference : 9581
3,90 €tax incl.
3,25 € tax excl.
He will dance on all festivals, ...
this cable. The diversity of its use possibilities is remarkable. Moreover, our RG cables are renowned for their inalterability and their long life. RG (Radio Guide) conductors are cables equipped with one or two shields per tubular braid and designed according to the American standard MIL-C-17. This standard of military origin is the best guarantee of a high quality and consistent quality and high strength. RG cables are intended for applications of various RF techniques and used primarily in transmitter and receiver systems, electronics and data retransmission.
ADVANTAGES :
  • Very long life due to the sheath resistant to aging
  • Precise and constant electrical characteristics
  • Easy to work
  • Adaptable to all standardized connectors
USE :
  • Transmission of data
  • HF technology
  • Construction of antennas
  • Fixed installations
  • Stereo connections
  • Technique inFormatique
Specifications:
Envelope, diameterPTFE 2.5 mm
AWG25
Conductor inside0.16 mm2
Inner diameter, diameter0.45 mm
Copper strands per coreStaku silver 7 x 0,17 mm
Insulation of the conductorPTFE 1.52 mm
Protectionsilver copper braid
Optical cover95%
Operating temperaturemin. -35 ° C
Operating temperaturemax. 80 ° C
Fire resistance per m0.12 kWh
Weight per m15 g
Packaging unit, packing unitcrown 100 m / roll 500 m
Suitable connectorBNC0.3 / 1.8
Suitable connectorSMAF316-AU
Suitable connectorSMAM316-AU
Suitable connectorSMB174
Colortransparent
Electrical Specifications :
Metric Capacity Screen / Display95 pF
Characteristic impedance per km+/- 3% 50 Ohm
Reduction factor0.66
Reduction per 100 m (20 ° C)100 MHz: 28.0 dB
Reduction per 100 m (20 ° C)200 MHz: 40.0 dB
Reduction per 100 m (20 ° C)500 MHz: 68.0 dB
Reduction per 100 m (20 ° C)800 MHz: 90.0 dB
Length (m)Sold by length
Trés bon cable phono !
Utilisé en deux fois 1.2m relié à une mini din Elecaudio pour remplacer le cable d'origine de mon bras (adc alt1) le résultat a dépassé mes espérances : Plus de clarté, de dynamique, son "plein", fini les sibilances et fini les ronflettes 50 hz, que du bon et du plus, vivement recommandé !
This review has been posted for SOMMERCABLE CLASSIC MKII RG316/U FEP Audio / Video Cable 50 Ohm Ø 2.5mm
