that one day, the luminous fiber bundles of the 1970s would be used to transport digital audio signalsthe
Compared to cheap optical fibers with a capacity of 0.4 dB / m and already faulty from a distance of 6 meters, the SC-OCTOPUS driver has a attenuation value of less than 0.16 dB per meter and guarantees excellent retransmission characteristics, also over long distances.
Thanks toa minimum radius of curvature of 30 mm, the SC-OCTOPUS can also be installed in narrow spaces. The optimum wavelength is 660 nm.
The outadapters, converters and connectors (Toslink) for individual manufacture can be found in chapter "Connectors".
ADVANTAGES :
USE :
Specifications: | |
Constitution | IV xx-2Y1P 980/1000 μm |
Envelope, diameter | S-PVC, PUR 6.0 mm |
Conductor inside | PMMA fiber 980/1000 μm |
Operating temperature | min. -20 ° C |
Operating temperature | max. 70 ° C |
Weight per m | 37 g |
Packaging unit, packing unit | per meter |
Suitable connector | POF-TOS |
Color | blue |
Type | simplex |
Electrical Specifications : | |
Digital Output | 0.50 |
Affaiblissement per m | 850 nm: 1.90 dB |
Impairment by m | 650 nm: 0.16 dB |
Typical wavelength | 660 nm |
