SOMMERCABLE SC-AQUA MARINEX MIKRO 25 AES / EBU Cable 2x0.25 mm² Ø7,20 mm
Reference : 15279
7,50 €tax incl.
6,25 € tax excl.
Shipping date: 23-04-2025.
The SC-AQUA MARINEX MIKRO 25 cable by Sommer Cable is suitable for AES / EBU use as well as as microphone instrument cable.
Equipped with waterproof insulation, it is designed for use in a wet environment (sound system for swimming pools, boats, greenhouses, outdoors) and even supports permanent immersion up to 50 meters deep. This sealing is made possible by a double insulation made up of two braided screens in counter-opposition. While this gives the entire cable greater rigidity than traditional PVC cables, this insulation also provides mechanical protection against shocks, crushing or tearing of the cable.
SPECIFICATIONS
UsageUnderwater / submerged
Digital 110 Ω AES / EBU
Stage / live
Halogen-free / LSZHYes
Colourblack
Signal transmissionsymmetrical
Jacket materialPUR-SR
Jacket Ø [mm]7,20
Number of Channels (audio)1
Inner conductor (audio)2
Inner conductor (audio) [mm²]0,25
AWG (audio)23
Shielding2 x copper spiral + special protective banding
Shielding factor [%]95
Copper strands (audio)32
Copper strand Ø (audio) [mm]0,10
Conductor insulation materialPUR
Conductor insulation Ø [mm]1,60
Weight per 1 m [g]65
UV-resistantyes
Fire load per m [kWh]0,27
Style variantround
Temperature min. [°C]-40
Temperature max. [°C]80
Width [mm]7,2
Height [mm]7,2
Capac. cond./cond. per 1 m (audio) [pF]50
Capacity wire/wire at 1 ft. (audio) [pF]15,24
Capac. cond./shield. per 1 m (audio) [pF]190
Capacity wire/electic screen at 1 ft. (audio) [pF]57,912
Impedance [Ω]110
Insulation resist. per 1 km [GΩ]1
Insulation resist. per 1000 feet [GΩ]3,048
Insulation resist. per 1 km (audio) [GΩ]1
Insulation resist. per 1000 feet (audio) [GΩ]3,048
Conductor resistance per 1 km [Ω]78
Conductor resistance per 1000 ft. [Ω]237,744
BPVo-EuroclassFca
Diameter (mm)7.2
Number of conductors2
Insulation materialPolyurethane (PUR)
ShieldingYes
Section (mm²)0.25
Ground / ShieldingYes
Utilisé en cable de modulation RCA
Très bien, de belles basses, un son plein, une belle énergie.
This review has been posted for SOMMERCABLE SC-AQUA MARINEX MIKRO 25 AES / EBU Cable 2x0.25 mm² Ø7,20 mm
