[GRADE S] USB Cable Silver Plated OFC Copper PTFE Double Shielding Ø7.8mm 2m
Refurbished product - Grade S
This cable allows the production of high quality digital audio USB models with noble materials. The conductors are PTFE insulated. The conductive part on 4 wires is made of OFC (Oxygen Free Copper) 4N (99.99%) silver plated.
Reference : 17784
Refurbished
19,80 €tax incl.
16,50 € tax excl.
This product is sold in the form of 2m offcut pieces of cable.
Câble USB PTFE Double Blindage Cuivre OFC Plaqué Argent Ø7.8mmThis cable allows the production of high quality digital audio USB models with noble materials. The conductors are PTFE insulated. The conductive part on 4 wires is made of OFC (Oxygen Free Copper) 4N (99.99%) silver plated.
This very well designed cable also includes cotton wire for a better mechanical resistance of the whole. A double shielding by copper braid and aluminum foil guarantees a high immunity to parasitic noises.
Moreover this cable has a rare specificity. The DATA wire and 5V voltage part are separated by shielding guaranteeing a low rate of parasitic noises between the conductors. A reason choice to design all affordable high level digital audio USB cable.
We recommend the following gold-plated USB plugs for better contact:
Characteristic and structure of the cable :
  • 4x 0.5mm² OFC 4N silver plated PTFE insulated
  • Double shielding copper braid aluminum foil + shielding 2 conductors
  • High resistance yellow PE outer sheath
  • External diameter: Ø 7.8mm
  • Length: 2m
Diameter (mm)7.8
Number of conductors4
Insulation materialPTFE
Section (mm²)0.50
Refurbished GradeGrade S
Ground / ShieldingYes
Refurbished product - Grade S This cable allows the production of high quality digital audio USB models with noble materials. The conductors are...
