USB Cable Silver Plated OFC Copper PTFE Double Shielding Ø7.8mm
This cable allows the production of high quality digital audio USB models with noble materials. The conductors are PTFE insulated. The conductive part on 4 wires is made of OFC (Oxygen Free Copper) 4N (99.99%) silver plated.
4.7 / 5
Reference : 11077
9,90 €tax incl.
8,25 € tax excl.
Câble USB PTFE Double Blindage Cuivre OFC Plaqué Argent Ø7.8mmThis cable allows the production of high quality digital audio USB models with noble materials. The conductors are PTFE insulated. The conductive part on 4 wires is made of OFC (Oxygen Free Copper) 4N (99.99%) silver plated.
This very well designed cable also includes cotton wire for a better mechanical resistance of the whole. A double shielding by copper braid and aluminum foil guarantees a high immunity to parasitic noises.
Moreover this cable has a rare specificity. The DATA wire and 5V voltage part are separated by shielding guaranteeing a low rate of parasitic noises between the conductors. A reason choice to design all affordable high level digital audio USB cable.
We recommend the following gold-plated USB plugs for better contact:
Characteristic and structure of the cable :
  • 4x 0.5mm² OFC 4N silver plated PTFE insulated
  • Double shielding copper braid aluminum foil + shielding 2 conductors
  • High resistance yellow PE outer sheath
  • External diameter: Ø 7.8mm
Diameter (mm)7.8
Number of conductors4
Insulation materialPTFE
ShieldingYes
Section (mm²)0.50
Ground / ShieldingYes
6 reviews
Very satisfied with the wire construction and the final sound quality.
This review has been posted for USB Cable Silver Plated OFC Copper PTFE Double Shielding Ø7.8mm
Caâle USB de bonne facture, que l'on peut rendre très bon !
Genèse d'un câble USB qui apporte un réel plus, à base d'éléments de chez Audiophonics...
Il y a 7 m entre la sortie de mon PC qui assure le rôle de source et l'entrée USB du DAC.
Le but est de concevoir un câble d'une seule pièce, puis de gagner en restitution sonore.
Mission accomplie !
Première étape :
Cable USB OFC PTFE Double Blindage Plaqué Argent Ø7.8mm
VIBORG UA201 Connecteur USB-A 2.0 Mâle Plaqué Or 24k Ø8.5mm
VIBORG UB201 Connecteur USB-B 2.0 Mâle Plaqué Or 24k Ø8.5mm
Je relie le blindage au connecteur uniquement du coté USB A, comme il est d'usage.
Musicalement à ce stade, c'est bon mais il n'y a encore rien d'extraordinaire.
Sur mon installation, j'ai toujours ce petit bruit numérique qu'on entend en poussant un peu le volume de l'ampli :
sans signal délivré par le PC, il y reste ce voile de son.
Je me dis qu'il y doit y avoir moyen d'améliorer cela.
La magie va venir d'un concept de blindage que j'ai voulu tester : JSSG 360
Petite recette DIY pour un câble USB qui a changé mon installation : plus d'ouverture, de dynamique.
Plus de finesse dans les instruments, de micro détails qui apparaissent et un bruit de fond réduit à néant.
NB : le plus simple est de faire toutes les opérations qui suivent avant de souder les connecteurs USB-A et USB-B.
Deuxième étape :
Glisser autour de la gaine jaune du câble USB une 1ère gaine de blindage tressée.
ELECAUDIO GC-0410 Gaine de blindage tressée 100% Cuivre 4-10mm
La gaine de blindage ne doit toucher ni les extrémités du câble, ni les (futures) prises USB.
C'est curieux, un blindage qui n'est relié électriquement à rien...
Justement !
J'ai laissé environ 1 cm sans gaine de blindage à chaque extrémité du câble USB.
(prévoir plus d'1 cm si vous soudez les prises après et que vous avez besoin de dénuder le câble USB pour accéder aux 4 fils Vcc, d+, d- et 0V).
On peut utiliser de la gaine thermorétractable ou du scotch électrique pour fixer les extrémités de cette 1ère gaine de blindage à l'isolant jaune du câble USB.
Ensuite, on glisse au dessus une gaine isolante, plus courte.
ELECAUDIO SG-03 Gaine Tressée Extensible Nylon (PET) 06-11mm
J'ai laissé environ 5 cm de gaine de blindage non recouverte à chaque extrémité.
J'ai donc maintenant 5 cm de gaine de blindage visible à chaque extrémité du câble.
Là encore, scotch ou gaine thermo pour fixer les extrémités de cette gaine isolante.
Puis par dessus la 2ème gaine de blindage, qui doit recouvrir entièrement la 1ère gaine de blindage.
scotch, gaine thermo...
Et enfin, la dernière gaine isolante qui recouvre toute la longueur du câble USB cette fois.
Gaine thermo pour que ça soit joli et que rien ne bouge, et en longueur suffisante pour bien écraser les 5 cm de gaine de blindage en dessous.
En résumé, on crée autour du câble USB un blindage double, connecté électriquement à ses 2 extrémités, mais flottant.
Flottant, c'est à dire qu'il n'est connecté à aucun potentiel électrique.
Ni à la masse.
A rien.
Ce type de montage peut aussi s'utiliser sur les câbles réseau, et on trouve dans le commerce des câbles tous prêts (mais à prix conséquents) avec ce double blindage flottant.
Bonne écoute !
 (4)
voilà un câble de qualité
De très bons conducteurs avec de bons isolants, des blindages là où il faut et un fonctionnement parfait en usb sans échos de retour dans le signal.
Conforme aux description
Totalement conforme à la description d'Audiophonics et des deux autres avis précédent.
je rajouterai une dimension tactile qui fait référence à la douceur de la gaine nous transportant dans le domaine du hi-end.
Ps: je conforme la qualité sonore.
bien mieux qu'un cable standart
Ce câble est épais mais souple, la fabrication est convaincante, double blindage.
Le son est nettement meilleur qu'avec le câble standard que j'utilisais, moins de dureté et une bonne articulation. Et j'aime bien la couleur... même si de toute façon il ne se voit pas là ou il est.
This cable allows the production of high quality digital audio USB models with noble materials. The conductors are PTFE insulated. The conductive...
