New edition completely redesigned of the famous interfaces of the mark, this time it equipped with an R-Core transformer.
This interface is now equipped with a Class A power stage with 5 separate groups and allows DSD and DXD compatibility via I2S (RJ45).
This asynchronous USB interface is for us one of the best on the market as well in terms of both decoding and sound.
Your computer will not have anything to envy other top-of-the-line digital sources thanks to the ultra-modern VT 1731 (32bit / 384khz) Audio-GD USB32 interface.
This 2014 version also has an SPDIF input that can be selected by the front button.
This interface comes with the TCXO option (high precision) allowing one of the lowest possible jitter.
Features:/ Strong>
Food | 210 - 240V |
Output Level | 0.5 Vp-p (at 75 Ohm) @ SPDIF 3.3V pp (25MA) @ I2S |
Input sensitivity | 0.5 Vp-p (75 Ohms, Coaxial) 19 dBm at Optical USB1.0, USB2.0, USB3.0 (Full Speed, High Speed, Class2) |
Sampling rate Span>supported (input) P> | Optical mode: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 48kHz, 48kHz, 88.2kHz, 96kHz, 192kHz, 192kHz, |
Sampling rate Span>supported (Output) Span> P> | fashionUSB to I2S: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz, 352.8kHz, 384kHz (Up to 32bit) fashionCoaxial to I2S: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 192kHz (Up to 24bit) fashionUSB to coaxial: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz (Up to 24bit) Coaxial to Coaxial: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 192kHz (Up to 24bit) |
Consumption | 8W |
Weight | Approx 2.5KG |
Dimensions | W180 X L220 X H55 (MM, Aluminum casing) |
Accessories | USB cable x1 |
[Img-10316-left-thickbox_default] P>
[Img-10318-left-thickbox_default]
