AUDIO-GD DI-25HE Digital Interface
New
The Audio-GD DI-25HE digital interface is based on an Amanero Combo 384 USB module coupled to a pair of Accusilicon 90/98MHz clocks. The circuit is designed to offer a plethora of options with regard to the strategies for using the clocks: interfacing from the internal clocks, using an external clock (slave mode) or offsetting the internal clock to a third-party device (master mode). This type of circuit allows integration into highly advanced audio systems.
By buying this product you get 119 loyalty points
Reference : 20580
1 199,00 €tax incl.
999,17 € tax excl.
Shipping date: 15-04-2025.
Audio-GD DI-25HE Digital Interface Amanero Accusilicon 32Bit 384kHz DSD512
Audio-GD DI-25HE : Front view
An Altera FGPA logic circuit is responsible for generating the output signal. This high-frequency chip is isolated from the USB interface to avoid any parasitic noise, both in terms of signal conversion and clock signal accuracy.
Audio-GD DI-25HE: New features
  • New HDMI I2S input port
  • The HDMI I2S input limits jitter, resynchronises the clock signal and data, and regenerates the clock signal, improving the sound quality of the connected source.
  • The pinout of the source's HDMI I2S output must be identical to the diagram opposite and the source's MCLK signal must be less than 40MHz (most sources incorporate a 24.576MHz clock which may be compatible with the DI-25HE's HDMI input).
  • The new clock configuration improves sound quality for all inputs.
Audio-GD DI-25HE : Pinout I2S
Audio-GD DI-25HE: Other features
  • Integrated regenerative power supply, designed using Class A power supplies and symmetrical Class A amplifiers.
  • The Amanero USB interface offers excellent compatibility and stability. It is compatible with Windows, OSX, iOS and Linux systems and has been tested with certain models of Android TVs and smartphones.
  • The HDMI I2S output supports PCM and DSD formats. The sampling rate can be displayed on the front panel screen.
  • The USB interface and FPGA processor use the same clocks to avoid affecting sound quality.
  • The FPGA data processing mode can be parallel or serial.
  • The screen can display the PCM and DSD sampling rate and can be used to view and select parameters.
  • Integrated USB firmware update button and FPGA firmware update connector.
  • Integrated 50Ω and 75Ω external clock input ports.
  • Integrated 10MHz clock generator. FPGA provides jitter and phase noise reduction. The 50Ω and 75Ω clock outputs allow operation as an external clock, feeding the DAC's 10MHz signal. The clock outputs can be switched between internal and external clock using front-panel buttons.
  • On-board isolator. Isolation of USB input and 10MHz clock input.
  • R-Core transformer and 13 groups of power supplies to power the various circuits independently.
  • All output circuits are powered by Class A power supplies for improved analogue feel. The USB interface, FPGA and clocks are powered by 4 groups of DC power supplies and 5 groups of ultra-fast linear power supplies.
Audio-GD DI-25HE: Regenerative power supply
Audio-GD's HE series features Regenerative Power Supply technology, which has undergone extensive testing and research to achieve its current incredible performance. This technology uses a thick aluminum plate to separate the power supply circuits, shields the main power supply circuit and limits the transmission of interference between the power supply and the audio circuits. The quality of this power supply system can be felt right from the first listen, with more detailed reproduction, greater dynamics, deeper bass and a wider soundstage. What's more, this technology also offers a more "analog" sound reproduction.
Audio-GD DI-25HE : Regenerative power supply diagram
Audio-GD DI-25HE Connectors
Audio-GD DI-25HE : Connector diagram
1Firmware update port and USB firmware reset button
2I2S HDMI input
3USB-B input
4Power connector
5110Ω AES/EBU output
675Ω coaxial output
7BNC 75Ω 10MHz output
8BNC output 50Ω 10MHz
9I2S HDMI output
10BNC input 75Ω 10MHz
11BNC input 50Ω 10MHz
Product typeDigital interface
Inputs1x USB-B
1x Clock input 10MHz BNC 50Ω (0.3Vpp - 3Vpp)
1x Clock input 10Mhz BNC 75Ω (0.3Vpp - 3Vpp)
1x HDMI I2S input
Outputs1x I2S HDMI LVDS 3.3V @ 100Ω
1x Coaxial 0.5Vp-p @ 75Ω
1x AES/EBU 5Vp-p @ 110Ω
1x Clock output 10MHz BNC, > 9dBm @ 50Ω
USB compatibilityWindows
OSX
Linux
ISO
Supported sampling ratesUSB / I2S : PCM up to 32bit 384kHz, DSD up to DSD512
AES/EBU / SPDIF : PCM up to 384kHz
Supply voltage220-240VAC 50/60Hz
Consumption17W
Dimensions360 x 240 x 85mm
Weight5kg
Package1x Audio-GD DI-25HE
1x USB cable
1x Power cable
InputI2S via HDMI
InputBNC
OutputAES/EBU
OutputI2S LVDS via HDMI
OutputBNC
OutputCoaxial SPDIF
Max sampling rate384kHz
Max sampling rateDSD512
Interface chipAmanero 384
AUDIO-GD DI-25HE Digital Interface Amanero Accusilicon 32Bit 384kHz DSD512
The Audio-GD DI-25HE digital interface is based on an Amanero Combo 384 USB module coupled to a pair of Accusilicon 90/98MHz clocks. The circuit is...
