AUDIO-GD DI-U8 R-Core Digital Interface XMOS XU208 HDMI I2S DSD 32bit/384khz
Audio-GD DI-U8 R-Core Digital Interface XMOS U8 HDMI I2S DSD 24bit/192kHz
By buying this product you get 41 loyalty points
Reference : 10575
419,00 €tax incl.
349,17 € tax excl.
AUDIO-GD DI-U8
XMOS XU208 Digital Interface
Efficient, multi-tasking, and affordable!
The DI-U8 is a newly redesigned edition of Audio-GD's famous digital interfaces, featuring an XMOS XU208 interface, an R-CORE transformer, and an I2S output.
This device has 4 outputs: Coaxial SPDIF and BNC (24bit / 192kHz), in addition to the I2S via RJ45 or HDMI (32bit / 384kHz). As well as 3 inputs: Coaxial SPDIF and Optical (24bit / 192kHz), and USB-B (32bit / 384kHz).
A modern USB interface
This digital interface, thanks to its XMOS XU208, allows you to play files up to 32bit / 384kHz in I2S, as well as USB. In order to use the DI-U8 via its USB input on the rear panel, with a Windows PC, you must first download the USB Driver XMOS from the Audio-GD website:br>XMOS U8 USB Interface
Exceptional decoding and sound reproduction
32bit / 384kHz / DSD / DXD / I2S / HDMI
The DI-U8 is for us one of the best interfaces on the market, in terms of its decoding capacities as well as its sound rendering, through its various inputs / outputs available.(s)div-text-editor text-center-div-style = "font-size: 15px" font-family: Muli, Arial; ; ">This version also has an SPDIF input, which can be selected by the selector on the front panel: 3 inputs possible. A pure and simple façade.
R-Core Transformer
This Audio-GD interface is equipped with an R-Core transformer known for its efficiency, its efficiency, and its loss of flux very low. It also has a Class-A power stage with 5 separate groups, for a consumption of only 8W.
XMOS XU208 Asynchronous
This XMOS XU208, one of the best audio interfaces on the market, supports compatibility with DSD and DXD files via I2S (RJ45 port or HDMI), up to 32 bit / 384kHz. Moreover its composition allows it to obtain a jitter very low. Your computer will no longer have anything to envy other high-end digital sources through it.
Features:/ Div>
Output Level: 0.5Vp-p (at 75 Ohm, SPDIF)
3.3Vp-p (25mA, I2S)
sensibInput Type: 0.5Vp-p (75 Ohm, Coaxial)
19dBm (Optical)
USB 1.1, USB 2.0, USB 3.0 (Full Speed, High Speed, Class 2)
Input Sampling Rate: USB (44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz, 352.8kHz, 384kHz)
Coaxial: (44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz)
Optical: (44.1kHz, 48kHz, 88.2kHz, 96kHz)
Sample rate (output): USB to I2S (44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz, 352.8kHz, 384kHz - up to 32 bit)
Coaxial to I2S: (44.1kHz, 48kHz, 88.2kHz, 96kHz, 192kHz - Up to 24 Bit)
USB to Coaxial: (44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz - up to 24 bit)
Coaxial to Coaxial: (44.1kHz, 48kHz, 88.2kHz, 96kHz, 192kHz - Up to 24 Bit)
Power Consumption: 8W
Weight: about 2.5kg
Dimensions: 180x220x55mm (Aluminum housing)
Included Accessories: Power cord / USB cable
4 reviews
Très bonne interface.
Utilisée avec un NFB 27H un ampli casque Prautes et un casque Kennerton Odin en liaison I2S RJ 45. L'amélioration est audible : plus de détails, d'aération.
This review has been posted for AUDIO-GD DI-U8 R-Core Digital Interface XMOS XU208 HDMI I2S DSD 32bit/384khz
Effet attendu et effet vérifié, petite boite magique
J'ai acheté ce boitier pour tenter de me rapprocher, avec mon Mac Mini, du superbe son que j'obtiens en branchant mon drive Rega Apollo R sur mon DAC NFB-7. Pour ce faire je passe par l'USB du boitier et j'utilise la sortie coax pour le NFB-7, et là, le plus est indéniable à tous les niveaux, et je rejoins tout à fait Mr Arnaud, la qualité obtenue est la même qu'avec une très bonne platine CD (idéal pour du 16/44). De plus j'utilise la sortie i2s reliée également avec un cable rj45 Audiophonics sur le DAC lorsque je veux passer du DSD, il suffit à ce moment là de changer l'input avec le sélecteur du NFB-7, lequel est bien mieux exploité à présent. Un conseil : utilisez le cable USB fourni par Audio-GD ou bien un cable compatible, mon ancien cable QED ne passait pas sur ma config (bug trouvé gràce à l'aasistance d'un technicien d'Audiophonics). Un boitier à consommer donc sans modération. Audiophonics toujours au top, commandé la veille et livré le lendemain à l'autre bout de l'hexagone.
Ou comment rendre aussi performant votre couple PC+DAC qu'une platine CD.
Bonjour,
Tout est dans le titre ou presque.
Avis tout à fait subjectif mais sur ma chaine Hifi composé d'un DAC Hegel HD11 + Intégré Atoll In200 + Cezanne HD + PC média (tout ce qui a de plus normal), je retrouve enfin les qualités que seule une platine CD pouvait m'offrir comme les silences, la neutralité, la scène sonore, exactitude du message, etc..
J'ai essayé / testé plusieurs solutions en interfaces digitales et c'est de loin celle qui m'a offert le plus de plaisir d'écoute sur la durée.
Très satisfait!
Associer lui un bon câble secteur et elle vous le rendra que mieux..
Très bon appareil
Cette interface fonctionne parfaitement. Elle n'est pas aussi lourde que l'on pourrait le redouter à voir le contenu du boitier, notamment l'alimentation. La finition est impeccable, et l'interrupteur + le sélecteur d'entrées en face avant, avec connectique à l'arrière sont très pratiques. La diode bleue éclaire assez fort, une diode blanche est fournie dans la boite comme option de remplacement (je n'ai pas essayé de l'installer).
J'ai intercalé la DI-U8 entre un Mac mini sous Audirvana et un NAIM DAC en liaison BNC (cable OYAIDE DB-510). Audirvana voit l'interface et affiche toutes les fréquences disponibles jusqu'à 384 Khz. Je sur-échantillonne systématiquement en multiple de 2 et les fichiers arrivent au NAIM DAC en 176 khz ou 192 khz (A+ Remote donne cette information précisément pour chaque morceau écouté).
Une précaution d'emploi : le sélecteur d'entrées est en façade et l'entrée USB est la numéro 3 (alors que ce sera probablement la plus utilisée) : j'avais sélectionné l'entrée 1 en première utilisation et bien sur... pas de son. Enfin, sachez que vous pouvez brancher l'interface en sortie sur plusieurs DAC en même temps. J'utilise ainsi un Yulong en connexion coaxiale, et je peux écouter soit au casque sur le Yulong, soit sur les enceintes à partir du NAIM DAC soit LES DEUX en même temps.
J'avais avant une interface MF 192. Le gain en qualité d'écoute existe (il faudrait que je fasse des écoutes comparées pour préciser, mais je n'en ai ni l'envie ni le temps). L'esthétique et l'ergonomie de l'audio GD s'ajoutant à celle d'Audirvana et A+ Remote ainsi que la possibilité de connexion en BNC avec le NAIM DAC (c'est son mode de connexion favori) ne m'incitent de toute façon pas à revenir en arrière.
