BERRYBAK BDC-U AA-AB41165 Interface USB DAC ES9018K2M Bluetooth 5.3 Receiver to RCA / Optical / Coaxial 24bit 96kHz
The BerryBak BDC-U multi-functional interface under reference AA-AB41165 is a Bluetooth/USB to RCA/Optical Toslink/SPDIF coaxial interface. It features audiophile components such as an ES9018K2M DAC chip, a Qualcomm QCC5171 Bluetooth 5.3 receiver chip and a WM8804 SPDIF interface. This enables it to support 24bit 96kHz streams, as well as high-resolution Bluetooth codecs: SBC, AAC, aptX, aptX HD, aptX Lossless and LDAC.
Reference : 19905
62,90 €tax incl.
52,42 € tax excl.
Shipping date: 22-04-2025.
Berrybak BDC-U AA-AB41165 Interface USB DAC ES9018K2M Bluetooth 5.3 receiver to RCA/Toslink/Coaxial 24bit/96kHz
Berrybak BDC-U AA-AB41165 picture
The BerryBak BDC-U multi-functional interface under reference Wondom AA-AB41165 is a Bluetooth/USB to RCA/Optical Toslink/SPDIF coaxial interface. It features audiophile components such as an ES9018K2M DAC chip, a Qualcomm QCC5171 Bluetooth 5.3 receiver chip and a WM8804 SPDIF interface. This enables it to support 24bit 96kHz streams, as well as high-resolution Bluetooth codecs: aptX, aptX HD, aptX Lossless and LDAC. Its inputs, outputs and components make it a versatile, high-performance interface of choice. It boasts a dynamic range of 127dB and a THD+N of -120dB thanks to the ES9018K2M chip, as well as low jitter thanks to the WM8804 chip. On the power supply side, there's a 5V 0.5A USB port and a 12V 0.5A Molex Micro Fit CKT port. The latter port provides an easy connection for those wishing to use this interface within a motorized vehicle such as a car to enhance the existing audio system, by enabling the interface to be powered directly from the vehicle's battery.
BerryBak BDC-U AA-AB41165: Bluetooth 5.3
This interface benefits from a Qualcomm QCC5171 Bluetooth chip, enabling it to support very high-resolution codecs: SBC, AAC, aptX, aptX HD, aptX Lossless and LDAC. The BerryBak BDC-U interface supports wireless transmission up to 24bit/96kHz with LDAC, and a transmission rate of up to 1Mbps with the aptX Lossless codec. These features offer the very best in wireless transmission.
Fonctionnalité Bluetooth du Berrybak BDC-U AA-AB41165
BerryBak BDC-U AA-AB41165: ES9018K2M DAC and WM8804 interface
Equipped with a USB input, the BerryBak BDC-U interface can easily use a source such as a smartphone or computer. This USB input supports sampling rates up to PCM 24bit 96kHz, thanks to the ES9018K2M DAC chip. This DAC chip also gives it a dynamic range of 127dB and a THD+N of -120dB. The WM8804 SPDIF transmitter with advanced jitter attenuation guarantees reliable signal transmission for the clearest, most accurate sound reproduction..
Berrybak BDC-U AA-AB41165 USB input
BerryBak BDC-U AA-AB41165: 12V power port with ACC control
Designed for easy integration into a car audio system, the BerryBak BDC-U features not only a USB-C power port (5V DC 0.5A), but also a 12V 0.5A power port on a Molex Micro Fit 2x2 CKT connector. The latter enables the interface to be connected directly to a vehicle battery. The ACC command synchronizes vehicle and interface starting. It also prevents the interface from drawing energy from the battery unnecessarily when the vehicle is not running.
12V power port for car audio installation
Berrybak BDC-U AA-AB41165 overview
1Bluetooth pairing LED indicator
2USB Audio input
3RCA output
4Bluetooth antenna
5SPDIF coaxial output
6Optical toslink output
712V DC MOLEX Micro Fit power port
85V DC USB-C power port
Berrybak BDC-U AA-AB41165 example of use
Product typeDAC/Bluetooth receiver interface
Bluetooth chipQCC5171
DAC chipES9018K2M
SPDIF interfaceWM8804
Inputs1x USB-C input
Bluetooth
Outputs1x Stereo RCA output
1x Coaxial output
1x Toslink optical output
Supported sample rates24bit 96kHz
SUpported Bluetooth codecsAAC, SBC, aptX, aptX HD, aptX Lossless et LDAC
RCA output level2Vrms
DNR127dB
THD+N-120dB
USB compatibilityWindows, Linux, Mac OSX (whitout driver)
USB standardUAC 2.0
Power supply5V DC 0.5A Via USB-C
12V DC 0.5A via Molex micro fit
Energy consumption0.48W
ColorSilver
Dimensions96 x 66 x 24.5mm
Weight248g
Package1x Berrybak BDC-U AA-AB41165
1x Bluetooth antenna
1x Molex micro fit connector cable to bare wires
1x Toslink optical cable
OutputOptical Toslink
OutputCoaxial SPDIF
DAC / ADC ChipES9018K2M
Max sampling rate96kHz
ColorSilver
Interface chipWM8804
Supported Bluetooth codecsAAC
Supported Bluetooth codecsLDAC
Supported Bluetooth codecsSBC
The BerryBak BDC-U multi-functional interface under reference AA-AB41165 is a Bluetooth/USB to RCA/Optical Toslink/SPDIF coaxial interface. It...
