DD TC100-COA Female USB-C to Male Coaxial Interface OCC Copper 75 Ohm 24bit 192kHz 35cm
The DD TCA100-COA is a high quality USB-C to coaxial adapter that provides USB connectivity to older DACs and amplifiers that have a digital coaxial input. It is then possible to connect to your devices more recent peripherals via a USB connection. Ideal for using a current smartphone as a source. The cable also supports PCM audio streams up to 24bit 192kHz.
Reference : 16888
89,00 €tax incl.
74,17 € tax excl.
This product is temporarily unavailable.
DD TCA100-COA
Female USB-C to Male Coaxial Digital interface OCC Copper 75 Ohm 24bit 192kHz 35cm
DD TCA100-COA Adaptateur USB-C Femelle vers Coaxial Mâle Cuivre OCC 75 Ohm 24bit 192kHz 35cm
High quality components
To ensure the best transmission quality, the TC100-COA's coaxial cable center conductor adopts a design using 99.9999% pure OCC copper. The thickness of its conductor provides a constant impedance of 75Ω, crucial for coaxial transmission.
The TCA100-COA is also equipped with a Murata DA101C digital audio transformer. This one ensures a balance between the USB input circuit and the coaxial output circuit for an optimal transmission.
Product typeUSB / Coaxial interface
Connectors1x Male coaxial
1x Female USB-C
Length35cm
Supported sampling ratesPCM up to 24bit 192kHz
Cable conductor materialOCC copper
Cable impedance75Ω
Weight45g
ColorGris
OutputCoaxial SPDIF
Max sampling rate192kHz
ColorGray
Interface chipMurata DA101C
The DD TCA100-COA is a high quality USB-C to coaxial adapter that provides USB connectivity to older DACs and amplifiers that have a digital...
