By buying this product you get 148 loyalty points
The Hermes 12Th USB digital-to-digital converter or digital interface (DDC) from Denafrips is the result of 3 years of research and development by the brand, which benefits from its extensive expertise in the design of DACs and related technologies.
This interface will allow you to extend the digital connectivity of your audio system or computer, while improving sound quality. What's more, the Hermes works perfectly with a wide range of DAC brands and models on the market. The data stream of the incoming USB digital signal is stored by the FIFO buffer and then reclocked using the built-in femtosecond clock. This procedure considerably minimises jitter, guaranteeing a signal free of digital noise. Furthermore, the Hermes 12th benefits from galvanic isolation, protecting the signal from electrical interference and maintaining signal integrity throughout the conversion process.
The power supply stage of the Hermes 12Th has also been optimised to provide all the circuits with a clean, stable electrical signal. These include a large 80VA UP-OCC copper O-Core transformer and precision LDO voltage regulators.
Key features:
A DDC or digital-to-digital converter transforms a digital audio signal from one format to another. Its primary purpose is to facilitate interconnections between different audio devices.
In addition to this conversion, Denafrips Hermes 12th uses advanced processing techniques to improve the sound quality of the output signal.
The Denafrips Hermes 12Th boasts a plethora of connections. Input is by USB-B, Coaxial, Optical Toslink or AES/EBU. On the output side you'll find I2S HDMI LVDS, I2S RJ45 LVCMOS, two AES/EBU ports, Optical Toslink and coaxial. The Hermes 12Th also features BNC inputs for connecting an external clock.
1 | AES/EBU Output |
2 | AES/EBU Output |
3 | I2S HDMI LVDS Output |
4 | I2S RJ45 LVCMOS Output |
5 | Optical Toslink Output |
6 | Coaxial Output |
7 | 49.152MHz Clock Input |
8 | 45.1584MHz Clock Input |
9 | Coaxial Input |
10 | Optical Toslink Input |
11 | AES/EBU Input |
12 | USB-B Input |
13 | Power connector |
Product type | Digital interface (DDC) |
Inputs | 1x USB-B 1x AES/EBU 1x Optical Toslink 1x Coaxial External clock inputs 45.1548MHz / 49.152MHz |
Outputs | 1x Coaxial 1x Optical Toslink 2x AES/EBU 1x I2S HDMI LVDS 1x I2S RJ45 LVCMOS |
Supported sampling rates | USB : PCM up to 768kHz, DSD up to DSD512 I2S : PCM up to 384kHz, DSD up to DSD512 Optical / Coaxial / AES : PCM jusqu'à 24bit 192kHz, DSD DoP jusqu'au DSD64 |
Supply voltage | 100-240V AC 50/60Hz |
Consumption | ≤ 20W |
Color | Black |
Dimensions | 330x240x50mm |
Weight | 4.5kg |
Package | 1x Denafrips Hermes 12TH |
Input | Optical |
Input | Clock (BNC) |
Input | SPDIF |
Input | AES/EBU |
Input | USB |
Output | Coaxial SPDIF |
Output | AES/EBU |
Output | Optical Toslink |
Output | I2S |
Max sampling rate | 768kHz |
Max sampling rate | DSD512 |
Color | Black |
Interface chip | FPGA |
