GUSTARD U12 XMOS USB interface I2S/SPDIF/AES EBU Out 32bit 384Khz
Gustard Xmos USB interface I2S/SPDIF Out 32 bit 384Khz
Reference : 11002
179,00 €tax incl.
149,17 € tax excl.
This USB interface Gustard U12 XMOS with a precision of 1PPM and a power of 500MIPS with FPGA processor offers a high level of resolution at a democratic price with a very low jitter.
The quality of its components (two clocks XO 45.4584MHz and 49.1520MHz), its processorAltera MAX II FPGAwith 8MB of built-in memory, its isolation bridge on I2S output predestines its use on high-end Hi-Fi systems.
This Asynchronous USB interface decodes its I2S output of the DSD QUAD and DXD 32 bit 384Khz and totally ASIO bit perfect under Windows (requires a driver provided on mini CD).
This interface is largely repeated in the DAC gustard X20, the flagship of the brand.
Its very neat linear power supply offers a very low level of noise guaranteeing the correct operation of the digital card preventing the jitter by electrical pollution.
An AES EBU I2S / HDMI USB interface dedicated to seasoned amateurs wishing to lose nothing of the integrity of their high definition dematerialized files.
HDMI / I2S compatibility :
The exitHDMI to I2S formatof the Gustard U12 XMOS interface is fully compatible with the entire range of DAC AUDIO GDand of courseGustard Audio.
Main Features :
  • USB interface type XMOS U8 32 bit 500MIPS with 8 cores 32Bit 384Khz.
  • Double XO type clock full 45.4584Mhz and 49.1520Mhz (1PPM).
  • Clock accuracy 45.4584Mhz: 0.167ps.
  • Accuracy of the clock 49.1520Mhz: 0.205ps.
Digital Inputs:
One USB Audio class 2.0 input.
Digital Outputs:
  • An I2S output on HDMI (see wiring diagram) 32bit 384Khz.
  • A standard output IEC60958 AES EBU 110Ohm XLR pins Gold plated 24bit 192Khz.
  • A coaxial output to standard IEC60958 PTFE insulation 75Ohm Plated Gold 24bit 192Khz.
  • A Toslink optical output with standard IEC60958 24bit 96Khz.
The bundle contains:
  • An IEC power cord of 1m75.
  • A mini CD containing the XMOS drivers.
Dimensions and weight:
  • 225x190x80mm.
  • Net weight 1kg.
  • Weight with packaging 1.3kg.
[Img-17220-left-thickbox_default]
[Img-17219-left-thickbox_default]
Output diagram I2S / HDMI.
[Img-17221-left-thickbox_default]
[Img-17226-left-thickbox_default]
[Img-18859-left-thickbox_default]
Superb digital interface
This digital interface is an excellent sounding unit. it takes several hours of break-in period but the result is Amazing, paired with THE CORRECT power cable (pay attention with this!)
It is very well built and the overall feeling is from a high quality finisth standard. For the price, nothing to compain about.
Plugged to a trusty Belden 19364 cable with iego gold plugs, the performance is shifted to stellar results,
a very worthy purchase!
This review has been posted for GUSTARD U12 XMOS USB interface I2S/SPDIF/AES EBU Out 32bit 384Khz
