IFI AUDIO IPURIFIER 2 SPDIF EMI Filter Galvanic Isolator Reclocker
The iFi Audio iPurifier 2 SPDIF is a small interface that functions as an EMI/RFI filter, galvanic isolation and reclocker. It provides you with a clean audio signal for improved playback.
Reference : 14822
199,00 €tax incl.
165,83 € tax excl.
Filtre EMI Isolateur Galvanique Reclocker
iFi Audio iPurifier 2 SPDIF Filtre EMI Isolateur Galvanique Reclocker
Most consumer devices, such as televisions, TV boxes or consoles, but also DACs or CD players, have SPDIF outputs. These can suffer from low quality transmission due to high jitter. The iPurifier 2, thanks to its ultra-fast 10MHz femtosecond clock, cancels the jitter for a precise and transparent restitution. A galvanic isolation limits the impact of interference on the signal and therefore the noise generated.
The iPurifier 2 SPDIF is compatible with DTS, Dolby Digital, DoP and DSD signals. It supports PCM streams up to 24bit 192kHz.
On the connector side, there is an Optical and Coaxial combo on mini-jack. For the outputs, the iPurifier 2 SPDIF is equipped with a Coaxial connector and an Optical mini jack connector, both being usable simultaneously.
Key points :
  1. Horloge femto Global Master 10MHz ultra-rapide.
  2. 4x 100µF tantalum capacitors for better ripple performance.
  3. Improved MCU firmware, performance optimization.
How it works
The signal passes through four stages: isolation, regeneration, memory buffer and reclocker. This assembly provides a clean signal, promoting a very high quality sound reproduction.
Buffer & Clock
The stage integrating the memory buffer and the AMT Global Master Timing system is a perfect solution to solve SPDIF signal jitter problems.
Galvanic isolation
The galvanic isolation of the SPDIF output allows a separation of the power supply circuits in order to effectively eliminate potential interferences that could alter the integrity of the audio signal.
Bit Perfect
The iPurifier 2 SPDIF can transfer a Bit Perfect signal to perfectly match the original audio message.
Product typzEMI/RFI filter
Galvanic isolator
Reclocker
Supported signal44.1 / 48 / 88.2 / 96 / 176.4 / 192kHz
16 to 24bit
DSD / DoP
Dolby Digital
DTS
Input1x Combo SPDIF Coaxial (75Ω) / Optical mini Jack
Outputs1x Coaxial (75Ω)
1x Optical mini Jack
Power supply5V 500mA via USB-C (iPower 5V included)
Dimensions76 x 19 x 20mm
Weight56g
ColorWhite
InputOptical Mini-Toslink
InputDIN 5
OutputOptical Mini-Toslink
OutputCoaxial SPDIF
Max sampling rate192kHz
ColorWhite
Interface chipNC
Parfait
Installé entre mon lecteur réseau (sans DAC) et un DAC Topping D70, l'écoute est transfigurée. Belle aération, élargissement de la scène sonore et surtout fluidité musicale, le stress dans les aigus ayant disparu. Ayant déjà expérimenté le IFI audio NANO GALVANIC qui m'a apporté la même impression sur une autre configuration (en USB), je ne peut que recommander cet accessoire indispensable à une écoute HIFI.
This review has been posted for IFI AUDIO IPURIFIER 2 SPDIF EMI Filter Galvanic Isolator Reclocker
The iFi Audio iPurifier 2 SPDIF is a small interface that functions as an EMI/RFI filter, galvanic isolation and reclocker. It provides you with a...
