IFI AUDIO ISILENCER+ EMI RFI Noise Suppressor Male USB-A to Female USB-A
The iFi Audio iSilencer+ applies effective filtering by connecting directly between your computer and your DAC. It eliminates electrical noise and EMI / RFI interference for clear, accurate and faithful sound reproduction.
4.4 / 5
Reference : 14476
59,00 €tax incl.
49,17 € tax excl.
Shipping date: 15-04-2025.
iFi Audio iSilencer+ Suppresseur de Bruit EMI RFI USB-A Mâle vers USB-A Femelle
The connection of audio devices via USB, while it allows high-resolution and bit-perfect data to be passed through, was not created specifically for audio, however. It therefore carries both data and power, which means that there is potential electrical noise from, for example, the power supply of your computer. The iFi Audio iSilencer+ solves this problem by applying effective filtering by connecting directly between your computer and your DAC. It eliminates electrical noise and EMI/RFI interference for clear, accurate and faithful sound reproduction, while improving bass.
The iSilencer+ can also be used on an unused USB port of a computer or DAC to reduce EMI interference. Each additional unit doubles this noise suppression capability.
In this version, the iSilencer+ has a female USB-A input and a male USB-A output.
An improved version
The iSilencer+ is a direct enhancement of the iDefender 3.0, now taking advantage of the Active Noise Cancellation 2 technology as well as the REbalance technology to remove distortion.
The circuit has also been improved, now incorporating low ESR tantalum capacitors for better input and output filtering. The filtering capacity has thus been multiplied by 10.
iFi Audio iSilencer+ Suppresseur de Bruit EMI RFI USB-C Mâle vers USB-C Femelle
Active Noise Cancellation 2 technology actively suppresses incoming noise, using similar operation to noise cancelling headphones. A signal identical to the incoming electrical noise is generated with an inverted phase, in order to perform this noise cancellation.
This method is particularly effective in eliminating noise at low and mid frequencies, while passive filtering takes care of interference at high frequencies. This clever combination is therefore more effective than simple passive filtering.
Thus, the measured noise is 100x or 40dB lower than what a conventional filter can offer.
REbalance
REbalance technology allows the signal to be rebalanced to correct problems caused by jitter. As a result, the digital signal received by the DAC is identical to that of the source, regardless of the format being played back.
USB 3.0 SuperSpeed
The USB 3.0 SuperSpeed standard allows faster transfer of audio data, while remaining backward compatible with previous standards. The iDefender+ is equipped with gold-plated connectors for excellent conductivity and resistance to oxidation.
Product typeUSB Noise suppressor
Input1x Female USB-A
Output1x Male USB-A
USB StandardSuperSpeed 3.0
Contacts platingGold
Total dimensions50 x 20 x 9mm
OutputUSB
Max sampling rateNC
Interface chipNC
5 reviews
Produit fragile à l'utilité incertaine
Inséré en sortie de PC, avant le cable usb alimentant un DAC, Cet accessoire n'a pas eu d'influence audible significative sur les performances audio de mon système. Au mieux un effet "placebo". En outre la connectique est fragile et cette clé usb s'est délitée au bout de quelques mois.
Je ne peux recommander un tel accessoire.
Laurent G.
This review has been posted for IFI AUDIO ISILENCER+ EMI RFI Noise Suppressor Male USB-A to Female USB-A
Instant upgrade!
I bought two and put the first one between my PC and a buss-powered 4-port USB 3.0 hub. The second one is plugged into the hub right before an iFi idefender. The iDefender then connects to a USB 2.0 hub that has been modified with grounding, extra shielding and power filtering. This hub then connects to a usb to coax decoder.
Each iSilencer added resulted in instant improvement! Sound became softer, more pleasant. Very happy with purchase!
I also tried putting them in empty USB jacks next to the cables but this didn't work as well. Seems to work best in series.
Recommandé
J'ai utilisé cet accessoire pour filtrer l'adaptateur Wifi sur port USB de mon serveur de fichiers musicaux, adaptateur qui donne à ce dernier la fonctionnalité Wifi et me permet de le piloter par mobile.
C'est efficace: L’amélioration due à l'accessoire, sans être considérable, est sensible. Plus de transparence, des détails musicaux apparaissent, le relief de la scène sonore est accru. Sur les bons enregistrements et notamment à partir des résolutions élevées (PCM 88/96 kHz et plus), les dimensions de la scène en volume s’accroissent nettement, de manière surprenante sur les bons enregistrements d'orchestre.
Aucun 'dégraissage', au contraire, il y a plus de grave (corps de contrebasse, de piano) et de médium. Les voix notamment féminines sont un peu plus chantantes et modulées, les timbres plus naturels. Enfin, la dynamique est accrue, sensation de live améliorée sur les enregistrements en public.
Sur les bons transferts d’enregistrement analogique pop (remasters récents en HighRes des Beatles et des Doors par exemple), la signature de l’enregistrement analogique d’origine est retrouvée.
Prévoir quelques jours de rodage avant d'atteindre le résultat décrit ci-dessus.
Cet accessoire maintient la fonctionnalité Wifi contrairement à d'autres marques qui filtrent 'tout' .. y compris le signal Wifi dès lors inopérant. A noter que l'accessoire, malgré l'extension physique qu'il représente, n’améliore pas (ni ne dégrade) la qualité de la réception Wifi par le serveur, ni la force du réseau Wifi créé par le serveur fonctionnant en mode hotspot.
Élément indispensable
L'ancien modèle amenait déjà une meilleure définition des timbres avec une plus grande ouverture, beaucoup de fluidité et d'aération.
Cette dernière mouture apporte en plus, de la précision, du détail, moins de duretés, et un grave mieux maîtrisé.
En résumé, un son plus naturel, plus analogique.
Un minuscule investissement pour un résultat saisissant.
The iFi Audio iSilencer+ applies effective filtering by connecting directly between your computer and your DAC. It eliminates electrical noise and...
