IFI AUDIO ISILENCER MAX EMI RFI Noise Suppressor USB-C
iFi Audio's iSilencer MAX is a USB-C filter designed to reduce noise and jitter in your signal, encapsulated in an aluminium case to ensure electromagnetic sealing. This filter has been designed with maximum compatibility in mind, and can withstand an electrical signal of 20V and 5A.
Reference : 19613
79,00 €tax incl.
65,83 € tax excl.
Shipping date: 08-05-2025.
iFi Audio iSilencer MAX EMI RFI Noise Suppressor Male USB-C to Female USB-C
IFI AUDIO ISILENCER MAX : Front view
iFi Audio iSilencer MAX: Active Noise Cancellation 3
Connecting audio peripherals via USB, while it allows high resolution and bit-perfect data to be transferred, was not created specifically for audio. It therefore carries both data and power, implying potential electrical noise from your computer's power supply, for example.
iFi Audio use a technology called Active Noise Cancellation 3, which involves duplicating the signal and inverting its phase, thus isolating the noise if it is present and eliminating it.
iFi Audio iSilencer MAX: REBalance Technology
USB standards include error detection systems, but not effective error correction. REbalance technology rebalances the signal to correct problems caused by jitter. As a result, the digital signal received by the DAC is identical to that of the source, whatever the format being played.
iFi Audio iSilencer MAX: USB 3.0 standard
The USB 3.0 standard enables faster transfer of audio data, while remaining backwards compatible with previous standards. The iSilencer MAX is equipped with gold-plated connectors for excellent conductivity and resistance to oxidation.
Product typeUSB Noise suppressor
Input1x Female USB-C
Output1x Male USB-C
USB Standard3.0
Contacts platingGold
Dimensions51.3 x 20 x 12mm
Weight21g
Package1x iFi Audio iSilencer MAX
Input
  • USB
Output
  • USB
Max sampling rate
  • NC
Color
  • Black
Interface chip
  • NC
IFI AUDIO ISILENCER MAX EMI RFI Noise Suppressor Male USB-C to Female USB-C
iFi Audio's iSilencer MAX is a USB-C filter designed to reduce noise and jitter in your signal, encapsulated in an aluminium case to ensure...
