Cet isolateur est remarquable, il rend justice aux musiques enregistrées et légitime l'usage d'un canal USB (sortie ordi-entrée DAC) sur un système HIFI de bon niveau
The iFi AUDIO USB isolator Galvanic 3.0 is an essential accessory for any user wishing to increase the performance of his dematerialized Hi-Fi installation. Once installed the sound is less tense, less digital, cleaner and looser with real qualities in the more natural harmonics.
STRONG POINTS :
By buying this product you get 39 loyalty points
The iFi Audio iGalvanic design for USB 2.0 or USB 3.0 is based on first-class galvanic isolation using audiophile-grade components. Glavan isolation is a process that separates and isolates unwanted noise from the digital and electrical signal. It also corrects the differences in ground potential, currents induced on the voltage.
The result is immediate with a better stability of the sound scene, integration of the audio message more realistic, harmonics of better quality eleminating the artificial, digital and acid side of the acute medium.
The bi-directional USB 3.0 technology is used to create a dual digital signal re-energization before and after galvanic isolation ensuring transmit and receive transmission quality.
On the iFi Audio isolator with the separation of the transmission and reception line in USB3.0 the galvanic isolation used actually does not weaken the DATA flow level always optimal.
Designed to have an extremely low floor noise (0.5uV) using panasonic and OS-CON capacitors, the entire power supply also benefits from galvanic isolation in conjunction with the digital DATA part.
The Zero Delayis an advanced isolation technology without any conversion steps, DSP processors that do not provide jitter and latency.
Output Voltage | 5V DC 500mA fully charged |
Output current | above 900 mA (USB 3.0) 500mA |
Voltage in entDC | 4.5V to 5.5V (USB voltage) |
Noise floor output | 0.0000005 V on a load of 500mA |
Earth connection | ISO, RF, DC-RF |
USB 3.0 and USB 2.0 transfer rate | |
USB 3.0 | Super Speed 5.0 Gbps |
USB 2.0 Hi Speed | 480Mbps |
USB 2.0 Full Speed | 12 Mbps |
USB 2.0 Low Speed | 1.5 Mbps |
Internal clock | |
Input host connector | USB 3.0 B-Type |
Host output connector | USB 3.0 A-Type |
Various | |
Power consumption | |
Dimensions | 93 x 67 x 28mm |
Weight | 128g |
Accessories | 1x USB cable |
Average votes 4.5 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
BERNARD L.
Robert M.
