IFI HDMI ISILENCER HDMI Female to HDMI Male EMI Noise Suppressor
iFi Audio's HDMI iSilencer is an HDMI filter designed to reduce noise and jitter in your signal and protect your equipment from surges that can be caused by electrostatic discharges.
4.7 / 5
Reference : 19597
89,00 €tax incl.
74,17 € tax excl.
Shipping date: 16-04-2025.
iFi HDMI iSilencer HDMI Female to HDMI Male EMI Noise Suppressor
Picture of iFi Audio HDMI iSilencer
Ifi Audio HDMI Isilencer : Active Noise Cancellation 2
Noise in cables can have several origins. The most common is poor or no shielding on cables or power supplies. Noise can also come from a switch-mode power supply, which is known to be noisy, or, more simply, from interference from other electronic devices.
In order to attenuate this parasitic noise, iFi Audio uses Active Noise Cancellation 2 technology, which duplicates the signal and reverses its phase, thus isolating and eliminating any parasitic noise that may be present.
iFi Audio HDMI iSilencer : Protection against overvoltage
What's more, iFi Audio's HDMI iSilencer features built-in overvoltage protection to ensure the safety of your equipment and protect it from electrical shock, including electrostatic discharge.
IFI HDMI ISILENCER : surge protection logo
iFi Audio HDMI iSilencer : Ultra HD/HDR 8K/60Hz and 4K/120Hz
Despite the filtering process applied, the HDMI iSilencer lets digital signals pass through perfectly to meet Ultra HD/HDR 8K/60Hz and 4K/120Hz standards, and works on HDMI 2.1 with extended backwards compatibility.
Example of use:
IFI HDMI ISILENCER : Example of use
Product typeHDMI Noise Suppressor
Input1x HDMI
Output1x HDMI
HDMI standardHDMI 2.1
Resolution supported8K/60Hz, 4K/120Hz Ultra HD HDR
Dimensions51.2 x 23.4 x 9.6 mm
Weight12.3 g
ColorBlue
Package1x iFi Audio HDMI iSilencer
InputHDMI
OutputHDMI
Max sampling rateNC
ColorBlue
Interface chipNC
3 reviews
Efficace
Sur oled sony avec mon lecteur uhd pana 820, on voit la difference en terme de colorimetrie, profondeur d image c est indeniable, par contre sur decodeur sat, je ne vois pas de difference...un bon achat pour de bonnes sources à la base
This review has been posted for IFI HDMI ISILENCER HDMI Female to HDMI Male EMI Noise Suppressor
efficace sur un lecteur blu ray!
Bonsoir ,c est le 2 eme hdmi ifi que j ai acheté ,et la je l ai testé sur mon pana 820 lecteur blu ray , je connais parfaitement mon tv et blu ray , apport du ifi apporte un contraste meilleur ,un piqué plus appuyé , et une fluidité plus souple a l image , dans le son ça apporte un son plus calme ,chaleureux . Le gain est un poil plus important sur mon lecteur blu ray que sur le decodeur canal , un hdmi sphere wireworld et hdmi isilenseur ( 180 euros) duo fantastique pour l image cela boustera votre lecteur blu ray ! Franck
un plus en image et son
Bonsoir , j ai mis IFI hdmi isilencer sur mon plasma via wireworld sphere , j ai remarqué que je gagne un peu en chaleur , largeur du son et l image est plus contrastée ,un poil plus de relief ,il y a des petits gains mais c est toujours bon a prendre . Franck
iFi Audio's HDMI iSilencer is an HDMI filter designed to reduce noise and jitter in your signal and protect your equipment from surges that...
