J'avais une interface Luckit, et là j'y ai gagné en tout, en plus il est joli, mais bon.
This new USB to SPDIF interface has 6 different types and formats of digital output. The DSD 256 11.2896Mhz via the official professional SDIF3 format on 3 BNC 75Ohms (DSD Sony Digital Format Interface).
This new USB to SPDIF interface has 6 different types and formats of digital output. The DSD 256 11.2896Mhz via the official professional SDIF3 format on 3 BNC 75Ohms (DSD Sony Digital Format Interface). It is aimed at the demanding amateur who wants an interface for almost all cases of connection in High Definition. It is therefore one of the few USB interfaces compatible DSD SDIF3 compatible with the DAC audio converters of the market like MYTEK, AYON, TASCAM or DCS.
This interface benefits from a construction in the rules of art with schemes particularly neat. The AES EBU and SPDIF coaxial parts in particular benefit from Pulse PE656 transformers for galvanic isolation of high-quality parasitic noise on a Neutrik gold-plated XLR symmetrical output. The entire SPDIF portion is managed by the Wilson / Cirrus Low Jitter DIR WM8005. The USB part has the now classic Xmos U8 with original clocks SCTF 24.574Mhz and 22.5792Mhz lowive PPM (jitter) with a management of the 5V USB by interface JA D1 and not of the source (computer).
In addition this USB interface has an II2S LVDS output on HDMI connector handled by Texas Instruments original fast logic gates. It is therefore compatible AUDIO GD, PS AUDIO, SMSL Audio, Matrix Audio, Gustard Audio, Armature Asterion.
The analog part of the JA-D1 features a balanced power supply with 4 LDO On-Semi NCP1117 regulators filtered by Audiophile capacitors Panasonic. The shielded and molded transformer is original Talema low-radiation double-winding. The chassis is made entirely of aluminum with a display indicating all sampling frequencies and inputs used.
Requires a Thesycon driver for Windows 7.8, 8.1, 10. Compatible Linux (depends on distributions) and Mac oS without driver. Windows drivers to download here
Mapping I2S / LVDS |
A synthesis of main IIS on LVDS pinouts mapping is available here. |
Input | USB |
Output | BNC |
Output | Optical Toslink |
Output | Coaxial SPDIF |
Output | AES/EBU |
Output | I2S LVDS via HDMI |
Max sampling rate | DSD256 |
Max sampling rate | 384kHz |
Color | Silver |
Interface chip | XMOS U8 |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
