LHY AUDIO UIP USB 2.0 Isolator Black
With its UIP, LHY Audio unveils a high-performance 480Mbps USB 2.0 isolator incorporating an internal OCXO + PLL clock system for perfect transmission of your sound signal via USB connectors. The LHY Audio UIP works plug and play thanks to a USB-B input and a USB-A output supporting the USB 2.0 protocol. USB isolation is achieved via an ADuM4165 chip and supports high-resolution PCM 32bit 768kHz and DSD512 streams.
3.0 / 5
By buying this product you get 54 loyalty points
Reference : 18765
549,00 €tax incl.
457,50 € tax excl.
Shipping date: 22-04-2025.
LHY AUDIO UIP USB 2.0 Isolator 480Mbps OCXO PLL Black
LHY Audio UIP picture
With its UIP, LHY Audio unveils a high-performance 480Mbps USB 2.0 isolator incorporating an internal OCXO + PLL clock system for perfect transmission of your sound signal via USB connectors. The LHY Audio UIP works plug and play thanks to a USB-B input and a USB-A output supporting the USB 2.0 protocol. USB isolation is achieved via an ADuM4165 chip and supports high-resolution PCM 32bit 768kHz and DSD512 streams. Moreover, if the UIP isolator's internal crystal oscillator clock doesn't suit you, LHY Audio offers you the option of connecting your own external clock via a 10MHz BNC connector (50Ohm/75Ohm). In short, the LHY Audio UIP USB isolator allows you to isolate the power supply and any ground loops from the USB ports for an improved audio signal.
Each component of this USB isolator is powered internally and independently by a power supply circuit consisting of a toroidal transformer, capacitors and LT3042 regulating transistors with PNP. Power is supplied via a 220-240V AC IEC power supply.
USB 2.0 Isolator LHY Audio UIP overview
Diagram of LHY Audio UIP components
1Ultra low noise filter capacitors
22x LT3042+PNP control transistor
3OCXO 10MHz clock + PLL
42x LT3042 control transistor
5ADUM4165 chip
6GND Switch
7Filter capacitor
8TALEMA transformer
9AC EMI/RFI filter
Rear view of the LHY Audio UIP
Product typeUSB isolator
Inputs1x USB-B 2.0
1x BNC 10MHz connector for external clock (50 Ohm / 75 Ohm) (Square wave 0.3V-3.3Vpp / Sine wave 0.5V-3.3Vpp)
Output1x USB-A 2.0
Max. flow rate480Mpbs
Plug and play
Power supply220-240V AC (mains cable not supplied)
Dimensions150 x 175 x 50mm
Weight1.5kg
Package1x USB 2.0 Isolator LHY UIP
OutputUSB
Max sampling rate768kHz
Max sampling rateDSD512
Interface chipADUM4165
Pas convaincu
Utilisé entre un streamer Melco N100 et un DAC Cen Grand DSDAC Deluxe, le rendu ne m'a pas convaincu. Le son ne s'est pas amélioré voir s'est montré un peu plus agressif. J'ai lu qu'il fallait une longue période de rodage pour que le coté agressif disparaisse pour laisser place à plus de fluidité mais après une semaine je n'ai pas vu d'amélioration. J'ai préféré renvoyer le produit avant la fin de le période d'essai.
This review has been posted for LHY AUDIO UIP USB 2.0 Isolator 480Mbps OCXO PLL Black
With its UIP, LHY Audio unveils a high-performance 480Mbps USB 2.0 isolator incorporating an...
