MUSICIAN PHOENIX Digital Interface I2S USB SPDIF 24bit 768kHz DSD512
Musician offers with the Phoenix a high-end digital interface, a real concentrate of technology aimed at providing an extremely clean and stable transmission of the audio signal. Practical, it has a complete range of connectors that will meet most needs, to adapt to the vast majority of audio systems. Moreover, it supports high definition audio streams, for the most accurate and transparent sound reproduction possible.
By buying this product you get 204 loyalty points
Reference : 16654
2 049,00 €tax incl.
1 707,50 € tax excl.
Musician Phoenix
Musician Phoenix Interface Numérique I2S USB SPDIF 24bit 768kHz DSD512
Proprietary USB interface
The USB-B input of the Phoenix is associated with a proprietary high-end USB interface, with an audio solution based on a proprietary MCU+FPU STM32F446 chip. This supports high-resolution audio streams, allowing playback of PCM files up to 24bit 768kHz and DSD512.
Altera Cyclone IV FPGA
The Musician Phoenix conceals a high performance Altera Cyclone IV EP4CE22 FPGA at its heart. It is responsible for processing and redistributing data signals to the various audio circuits, while ensuring a very low level of distortion.
Digital isolation
The digital signal of the Phoenix is fully isolated using a high speed 50Mbps optical coupler. This technology significantly reduces the noise level and thus achieves an excellent signal to noise ratio.
OCXO SC Cut Clock
The Musician Phoenix clock system uses two constant temperature OCXO (Oven Controlled Crystal Oscillator) SC Cut oscillators, offering extremely low noise. This type of oscillator uses a thermostatic bath to maintain the temperature of the quartz resonator at a fixed temperature and thus minimize frequency variations of the oscillator output.
Optimized power supply
The power supply stage of the Musician Phoenix benefits from the same care given to the audio circuits, in order to provide them with a clean and stable electrical signal. It includes an O-Type transformer made of high quality monocrystalline copper wire.
A complete connectivity
The Musician Phoenix offers a particularly complete connectivity, both in input and output, which will adapt to most needs. Thus, the device offers USB-B, AES/EBU, coaxial, optical Toslink and two inputs for external clock. For the outputs, the Phoenix offers AES/EBU, I2S via HDMI and RJ45 as well as Toslink optical and coaxial.
1USB Input selection
2AES Input selection
3Settings button
4Optical input selection
5Coaxial input selection
6OK Button
7AES/EBU Output
8I2S RJ45 Output - LVCMOS Standard
9Coaxial output
10Coaxial input
11AES/EBU Input
12I2S HDMI Output - LVDS Standard
13Optical Toslink output
14Clock inputs
15Optical Toslink input
16USB-B Input
17Power connector
I2S Pinout
Product typeDigital interface
Inputs1x USB-B
1x Optical Toslink
1x AES/EBU
1x Coaxial
1x 45.1548MHz clock input
1x 49.152MHz clock input
Outputs2x AES/EBU
1x I2S LVDS (HDMI)
1x I2S LVCMOS (RJ45)
1x Optical Toslink
1x Coaxial
Supported sampling ratesUSB : PCM up to 24bit 768kHz, Native DSD up to DSD512, DSD DoP up to DSD64
I2S : PCM up to 24bit 384kHz, DSD Natif up to DSD512, DSD DoP up to DSD64
AES / Optical / Coaxial : PCM up to 24bit 192kHz, DSD DoP up to DSD64
Supply voltage100-240VAC, 50/60Hz
Consumption≤ 20W
Dimensions345 x 250 x 85mm
Net weight5.5kg
InputAES/EBU
InputBNC
OutputI2S LVDS via HDMI
OutputAES/EBU
OutputOptical Toslink
OutputCoaxial SPDIF
OutputI2S LVCMOS via RJ45
Max sampling rate768kHz
Max sampling rateDSD512
Interface chipNC
Musician offers with the Phoenix a high-end digital interface, a real concentrate of technology aimed at providing an extremely clean and stable...
