By buying this product you get 62 loyalty points
Digital Interface I2S USB SPDIF 24bit 768kHz DSD512
Musician offers with the Pisces II a high quality digital interface, capable of providing a clean and stable transmission of the audio signal. It offers a complete range of outputs to suit most audio systems and needs. In addition, the Pisces supports high definition audio streams for the most accurate and transparent sound reproduction possible.
The USB-B input of the Pisces II is associated with a proprietary high-end USB interface based on a proprietary STM32F446 MCU. It supports high resolution audio streams, allowing the playback of PCM files up to 24bit 768kHz and DSD512.
The Musician Pisces II conceals in its heart a powerful Altera Max II FPGA. This one is in charge of decoding the digital data and allows to reduce the signal path while limiting the sound coloration.
The digital signal of the Pisces II is totally isolated using a high speed 50Mbps optical coupler. This technology allows to considerably reduce the noise level and to reach an excellent signal to noise ratio.
The Musician Pisces II clock system uses two TCXO (Temperature Compensated Crystal Oscillator) oscillators for very low jitter. The TCXO system automatically adjusts the external capacitance coupling matrix by measuring temperature, in order to provide a more accurate and stable frequency.
The power supply stage of the Musician Pisces II benefits from the same care given to the audio circuits, in order to provide them with a clean and stable electrical signal. It includes an O-Type transformer made of high quality single crystal copper wire.
The Musician Pisces II offers a complete connectivity, especially for its outputs, and will adapt to most needs. The device offers USB-B as input as well as two inputs for external clocks. For the outputs, the Pisces offers AES/EBU, I2S via HDMI and RJ45 as well as Toslink optical and coaxial.
1 | Settings button |
2 | OK button |
3 | I2S LVDS Output (HDMI) |
4 | Optical Toslink output |
5 | Clock inputs |
6 | I2S LVCMOS output (RJ45) |
7 | AES/EBU output |
8 | Coaxial output |
9 | USB-B input |
10 | Power supply connector |
Product type | Digital interface |
Inputs | 1x USB-B 1x 45.1548MHz clock input 1x 49.152MHz clock input |
Outputs | 2x AES/EBU 1x I2S LVDS (HDMI) 1x I2S LVCMOS (RJ45) 1x Optical Toslink 1x Coaxial |
Supported sampling rates | USB : PCM up to 24bit 768kHz, Native DSD up to DSD512, DSD DoP up to DSD64 I2S : PCM up to 24bit 384kHz, Native DSD up to DSD512, DSD DoP up to DSD64 AES / Optical / Coaxial : PCM up to 24bit 192kHz, DSD DoP up to DSD64 |
Supply voltage | 100-240VAC, 50/60Hz |
Consumption | ≤ 20W |
Dimensions | 250 x 235 x 70mm |
Weight | 3.5kg |
Color | Black |
Input | SPDIF |
Input | BNC |
Input | USB |
Input | Optical |
Input | AES/EBU |
Output | AES/EBU |
Output | Optical Toslink |
Output | Coaxial SPDIF |
Output | I2S LVCMOS via RJ45 |
Output | I2S LVDS via HDMI |
Max sampling rate | 768kHz |
Max sampling rate | DSD512 |
Color | Black |
Interface chip | NC |
