PHIREE U2SX USB to SPDIF Interface SA9023 OTG 24bit 96kHz Black
The Phiree U2S is a simple, efficient and compact USB to SPDIF and Optical interface. It is based on a Bravo SA9023 chip, supporting sampling rates up to 24bit 96kHz.
4.9 / 5
Reference : 10522
36,90 €tax incl.
30,75 € tax excl.
PhIree U2S 2019
USB to SPDIF Interface SA9023 24bit 96kHz Black
Phriee U2SX Interface USB vers SPDIF SA9023 24bit 96kHz Noir
The Phiree U2S is a simple, efficient and compact USB to SPDIF and Optical. It is based on a Bravo SA9023 chip, supporting sampling rates up to 24bit 96kHz. It also allows AC3 and DTS ES signals to pass through (to another multi-channel decoder).
On this U2S there is therefore a Micro USB port at the input and a Coaxial connector and a Toslink Optics at the output. The interface allows Micro USB input for optical or coaxial output, and the USB cable is included. All this is integrated into a robust but compact aluminium housing with soft curves.
The Phiree U2S interface is OTG compatible and can therefore be used with smartphones that are also OTG compatible.
Product typeUSB Interface
Inputs1x Micro USB
Outputs1x Coaxial SPDIF
1x Optical Toslink
Sampling rateUp to 24bit 96kHz
Case materialAluminium
Dimensions45 x 64 x 21mm
Weight50g
Package1x Phiree U2SX interface
1x USB-A to Micro USB Cable
OutputOptical Toslink
OutputCoaxial SPDIF
Max sampling rate96kHz
Interface chipSA9023
10 reviews
Fonctionne sur Mac
Fonctionne comme prévu sur MacMini M1 sans rien installer. Il s'agit du modèle U2S 2019 (selon macOS).
This review has been posted for PHIREE U2SX USB to SPDIF Interface SA9023 OTG 24bit 96kHz Black
Magique ....
Ce petit module est super pour envoyer le son d'un PC vers un équipement audio en ayant une isolation galvanique qui garanti
l'absence de boucle de masse et de toutes perturbations électriques.
Il est reconnu immédiatement sous Windows et s'enregistre dans la liste des périphériques audio.
Un excellent rapport qualité prix.
Audiophonics-Phiree U2S
Pour écouter les WebRadios j'utilise un ordi, la télé (comme moniteur) et une chaîne HiFi.
Le télé me permet de lancer l'écoute; ensuite je la mets en veille, pendant l'écoute.
L'ordi ne dispose pas de sortie SPDIF.
J'ai acheté chez Audiophonics un extracteur HDMI vers SPDIF. Le son était bon mais des coupures de signal sur la télé et sur la sortie HDMI de l'ordi m'ont obligé à retourner l'extracteur. Je remercie Audiophonics de m'avoir permis ce retour.
J'ai ensuite acheté le convertisseur USB vers SPDIF Phiree U2S.
Il fonctionne parfaitement (on doit sélectionner la sortie son Phiree sur l'ordi), sans rien avoir à installer.
Le son me convient tout à fait.
Il convient de pondérer cette appréciation par le fait que la plupart des stations de radio diffusent en MP3 (je privilégie toutefois les diffusions en MP4 (aac)) et aussi que mes oreilles de 74 ans n'ont plus la finesse qu'elles ont pu avoir. Dans ces conditions, l'achat d'un appareil plus coûteux n'était pas justifié.
Pour les lecteurs intéressés, je précise que j'utilise le (bon) convertisseur N/A intégré à mon graveur de CD Marantz.
Les personnes ne disposant pas de convertisseur N/A trouveront ce qu'il leur faut chez Audiophonics.
En conclusion, je recommande Audiophonics pour sa gamme étendue de produits proposés et pour le bon contact qui m'a permis d'obtenir le produit qui me convient.
Merci.
JF
Works as intented.
Excellent offering for the price. See my review and measurements there : https://www.audiosciencereview.com/forum/index.php?threads/phiree-u2s-2019-review-and-measurements-digital-usb-to-s-pdif-interface.29765/
 (4)
Surprisingly good
Used to replace the inbuilt TOSlink on motherboard. Everything sounded clearer and bass had more slam
The Phiree U2S is a simple, efficient and compact USB to SPDIF and Optical interface. It is based on a Bravo SA9023 chip, supporting sampling rates...
