RME BABYFACE PRO FS Balanced Digital / Analog USB Interface ADC 192kHz
-14%
RME returns with an improved version of its Babyface USB interface, the Babyface Pro FS. This new version benefits from numerous essential functions and updates to offer the best possible recording and sound reproduction quality.
Reduced price!
Reference : 14504
Limited special offer
949,00 €tax incl.
-14%
819,00 €tax incl.
682,50 € tax excl.
RME Audio Babyface Pro FS
RME Audio Babyface Pro FS Interface Numérique USB 24 Canaux 192kHz
Four years ago now, the Babyface Pro once again demonstrated RME's absolute commitment to top quality work, not only in audio circuitry and driver development, but also in mechanics. Created with the utmost precision from a block of Aluminium, this high-end portable interface incorporated newly designed analogue and digital circuits. Its innovative power-saving technologies achieved supreme fidelity without compromising on level, noise or distortion.
RME returns with an improved version of this USB interface, the Babyface Pro FS. This one benefits from the following features in particular:
  • A +19/+4 dBu switch underneath the unit provides a direct way to reduce the output level, improving the SNR for active monitors, avoiding distortion and overloads, while helping to keep the TotalMix FX faders close to 0dB instead of exhibiting high attenuation.
  • Complete SteadyClock FS circuit similar to the one present in the ADI-2 Pro FS for minimum jitter and higher jitter resistance.
  • 90mW amplified 3.5mm TRS jack headphone output. The THD of each headphone output is improved by 10dB. Now uses the same output AOPs as the ADI-2 Pro. The output impedance of the 3.5mm TRS jacks has been lowered from 2 Ohm to 0.1 Ohm.
  • The SNR of the microphone inputs has been improved from 112.2dB to 113.7dB, that of the TRS Line inputs from 114dB to 116.3dB (120dBA). The THD of the Line inputs has been improved by 8dB.
  • 6 samples with less latency on the AD side thanks to the new ADC (5 AD samples, 7 DA samples).
  • All of the above improvements have been achieved without increasing the power consumption of the device.
  • K-Slot for theft protection.
ADI-2 Headphone Amplifier
The two headphone outputs, with TRS and Mini Jack connectors in parallel, have independent amplification stages to adapt perfectly to low and high impedance headphones, guaranteeing a precise and pure reproduction, whatever the headphones used.
The 3.5mm TRS jack headphone outputs are capable of delivering 90mW of power. The THD of each headphone output has been improved by 10dB and each uses the same AOPs as the ADI-2 Pro. The output impedance of the 3.5mm TRS jack has been lowered from 2 Ohm to 0.1 Ohm.
Complete capture - Line inputs and Improved microphones
For the main inputs/outputs, RME has designed XLR connectors that integrate seamlessly into the housing while saving space.
Two digitally controlled preamplifiers provide individually switchable 48V phantom power. These circuits have a 76dB gain range, adjustable in 1dB steps, including a relay controlled PAD, resulting in excellent EIN (Equivalent Noise Level) and overload protection, while providing sufficient gain even for microphones with low levels.
The incredibly efficient design of the Babyface Pro means you never need external power. The interface is perfectly stable when powered via USB 3 and even via most USB 2 ports, with no degradation in technical specifications. This feature makes it an ideal interface for recording anywhere, including with condenser microphones.
This extensive feature set is complemented by a Toslink Optical I/O, which can be used as an ADAT port with SMUX support or as an SPDIF connector supporting sample rates up to 192kHz. Combined with an external ADAT converter (not included), the Babyface Pro supports 12 analog inputs and 12 outputs, ideal for live performances or multi-track studio recordings. You can connect any instrument, line or high impedance, thanks to the Jack 3 and 4 inputs. This makes it possible, for example, to simply record a guitar on the fly without any additional hardware. A MIDI input/output is also available via an included breakout cable, completing the many functions offered by the Babyface Pro.
Professional performance with the SteadyClock FS
In digital audio, the clock frequency is an essential factor, creating a correlation between the audio bits and the time reference. Unfortunately, the clock frequency is not always as stable as desired. The Babyface Pro FS thus embeds a SteadyClock FS circuit identical to that of the ADI-2 Pro FS, and allowing to reach an extremely low jitter level, and a very good resistance to it. These excellent performances in all clock modes and the high quality analog conversion allow you to hear your mix as it really is. RME products are converted to digital format without loss or degradation, and the SteadyClock FS provides a very transparent and rich sound reproduction. This allows you to optimize your recordings and mixes, due to the greater depth and clarity of the sound scene.
Mix & Routing with TotalMix FX and TotalMix Remote
Like all the latest RME interfaces, the Babyface Pro FS integrates the powerful real-time digital mixer TotalMix FX. It allows a complete and independent routing and mixing from the inputs and playback channels to all physical outputs. Stereo sub-mixes and an understandable Control Room section provide unparalleled monitoring capabilities as well as great routing flexibility.
The Babyface Pro is supplied with the RME TotalMix FX software, available for Windows, Mac OS X and iOS. This incredibly versatile software allows you to use the Babyface Pro in any situation. For example, mixing your guitar with vocals to headphones has never been easier. The FPGA-based mixing DSP adds an extremely flexible 3-band parametric EQ to all inputs and outputs. Reverb and Delay effects are also available.
In addition, the latest RME software, TotalMix Remote, offers remote control of the Babyface Pro FS via iOS, PC or Mac. Through a simple configuration process - simply enter the IP address of the computer you wish to control with TotalMix Remote - you can quickly set any TotalMix FX parameter on a host system from anywhere in your studio or even from a control room outside.
The latest generation of low latency AD/DA converter combined with the unique SteadyClock FS RME technology ensures excellent specifications that will satisfy the most demanding professionals. Add to this the Babyface Pro's many features, excellent sound performance and intuitive control and you have the most understandable and versatile compact audio interface ever created.
Easy to use and perfectly stable
The reference design of the Babyface Pro FS leaves nothing to chance. RME devices are designed to keep the audio signal as it really is. They are therefore transmitted in their entirety, nothing is added, nothing is removed. For the Babyface Pro, the audio circuits have been improved to adapt even to the highest gain levels with the best possible dynamic range. The user interface is clearly presented and offers a lot of information. It makes access to every function and configuration mode intuitive and easy to use.
RME USB - Audio transport with low latency and unsurpassed stability
As part of RME's product philosophy, the brand is always developing and optimizing their core technology. RME pioneered multi-channel audio and was the first to offer professional performance on a USB 2.0 interface. RME pays great attention to the development of reliable, stable and regularly updated drivers, while focusing relentlessly on audio quality.
And since RME Audio develops the core of its interfaces, they do not depend in any way on third party structures for improvements, modifications and bug fixes. So you can always benefit from the latest operating system.
Test du Babyface Pro FS par Audio Science Review
" RME sets the performance bar at "very competent" and easily meets that with Babyface Pro FS. Overall, I am happy to recommend the RME Babyface Pro FS. "
Product typeDigital interface
InputsBalanced XLR
Single-ended Jack 6.35mm
Optical ADAT / SPDIF
OutputsBalanced XLR
Single-ended Jack 3.5mm
Inputs/OutputsUSB-B
MIDI DIN 5 pins
Phantom power supply2x 48V
AD : Microphone / Line 1-2
InputXLR (electronically balanced)
Balanced input impedance2K Ohm
5.2K Ohm with PAD
Single ended input impedance1K Ohm
2.6K Ohm with PAD
SNR113.7dB RMS (unweighted)
117dBA
Frequency response18Hz - 20.8kHz @ 44.1kHz, -0.1dB
7Hz - 45.8kHz @ 96kHz, -0.5dB
5Hz - 88kHz @ 192kHz, -1dB
With PAD active-0.1dB 8Hz
-0.5dB < 4Hz
-1dB < 3Hz
THD< -112dB, < 0.00024%
< -115dB, < 0.00016% @ 30dB Gain
THD+N< -108dB, < 0.00035%
< -100dB, < 0.001% @ 30dB Gain
Channel separation> 110dB
Gain range-11dB to +65dB
Max XLR input level@ 0dB Gain : +8dBu, PAD +19dBu
@ 65dB Gain : -57dBu, PAD -46dBu
AD : Line/ Instrument Input 3-4
InputJack 6.35mm TS, single-ended
Input impedance1M Ohm
SNR116dB RMS (unweighted)
120dBA
Frequency response5Hz - 20.8kHz @ 44.1kHz, -0.1dB
< 3Hz - 45.8kHz @ 96kHz, -0.5dB
< 2Hz - 92kHz @ 192kHz, -1dB
-0.5dB < 4Hz
-1dB < 3Hz
Max input level@ +4dBu, 0dB Gain : +13dBu
@ -10dBV, 9dB Gain : -5dBu
DA : Line Output 1-2
OutputBalanced XLR
Dynamic range115dB RMS (unweighted)
118dBA
Frequency response0Hz - 20.8kHz @ 44.1kHz, -0.5dB
0Hz - 45kHz @ 96kHz, -0.5dB
0Hz - 89kHz @ 192kHz, -1dB
THD-106dB, 0.0005%
THD+N-102dB, 0.0008%
Output impedanceBalanced : 300 Ohm
Single-ended : 150 Ohm
Output level @ 0dBFSBalanced : +19/+4 dBu
Single-ended : +13/+7 dBu
DC @ 0dBFSJack 6.35mm 4.8V
Jack 3.5mm 2.4V
Balanced XLR 9.6V
DA : Jack 6.35mm Headphone Output 3-4
OutputJack 6.35mm TRS, single-ended
118dBA
SNR114.8dB RMS (unweighted)
118dBA
Noise level-101.8dBu
THD-106dB, 0.0005%
Output impedance10 Ohm
Output level @ 0dBFS, 10K Ohm+13dBu
Max power @ 0.1% THD60mW
Jack 3.5mm 2.4V
Balanced XLR 9.6V
DA : Jack 3.5mm Headphone Output 3-4
OutputJack 3.5mm TRS, single-ended
118dBA
SNR114dB RMS (unweighted)
117dBA
Noise level-107dBu
THD-106dB, 0.0005%
Output impedance0.1 Ohm
Output level @ 0dBFS, 10K Ohm+7dBu
Max power @ 0.1% THD90mW
Jack 3.5mm 2.4V
Balanced XLR 9.6V
MIDI
Input/Output1x Input/Output via breakout cable with DIN 2x5 pins connectors
Galvanic insulationBy optocoupled input
Hi-Speed modeJitter and response time < 1ms
Separate 128 byte FIFO for input and output 25.3-
Digital
ClocksInternal
ADAT input
SPDIF input
Jitter suppression of external clocks> 50dB (2.4kHz)
Effective clock jitter influence on AD and DA conversionNear 0
PLLEnsures zero dropout, even at more than 100ns jitter
Digital Bitclock PLLFor trouble free varispeed ADAT operation
Supported sampling rates28kHz to 200kHz
Digital Input : ADAT Optical
Input1x Toslink
Standard8 Channel 24bit, up to 48kHz
Double speed (S/MUX)4 Channel 24bit, 96kHz
Quad speed (S/MUX4)2 Channel 24bit, 192kHz
Bitclock PLLEnsures perfect synchronisation, even in varispeed operation
Lock Range31.5kHz - 50kHz
Jitter suppression> 50dB (2.4kHz)
Digital Input : SPDIF Optical
Input1x Optical (according to IEC 60958)
CompatibilityConsumer and professional format
Lock Range27kHz - 200kHz
Digital Output : ADAT Optical
Output1x Toslink
Digital Output : SPDIF Optical
Output1x Optical (according to IEC 60958)
Sampling rates28kHz to 200kHz
Power supplyVia USB or external power supply
ConsumptionIdle : 2.8W
Typical : 3.7W
Max : 5.4W
Current@ USB 5V power supply : 700mA (3.7W)
@ 12V external power supply : 313mA (3.7W)
Dimensions108 x 181 x 35mm
Weight680g
Temperature range+5°C / +50°C
Relative humidity< 75%, non condensing
InputXLR
InputMIDI
InputJack 6.35mm
OutputMIDI
OutputJack 3.5mm
OutputJack 6.35mm
OutputOptical Toslink
DAC / ADC ChipNC
Max sampling rate192kHz
ColorSilver
Interface chipNC
RME returns with an improved version of its Babyface USB interface, the Babyface Pro FS. This new version benefits from numerous essential...
