SINGXER SU-6 Digital Interface I2S USB XMOS XU208 32bit 384kHz DSD512
The Singxer SU-6 is a next-generation digital interface that delivers excellent audio performance through a high-end component-based design. These include an XMOS XU208 USB interface and a Xilinx FPGA. Two CCHD-957 femtosecond clocks provide an extremely low jitter level.
Reference : 14875
695,00 €tax incl.
579,17 € tax excl.
Singxer SU-6
Interface Numérique I2S USB XMOS XU208 32bit 384kHz DSD512
Singxer SU-6 Interface Numérique I2S USB XMOS XU208 32bit 384kHz DSD512
The SU-6 also has a particularly complete set of connectors, especially at the output. While it has a single input in USB-B 2.0 format, the output of the SU-6 includes AES/EBU, Coaxial, BNC and Optical SPDIF as well as I2S via RJ45 and HDMI. A MCLK/WCK output is also available to allow another device to use the clock signal from the SU-6.
The interface also supports high sample rates, allowing you to enjoy your PCM files up to 32bit 384kHz and DSD512 (via I2S).
This SU-6 from Singxer mainly integrates 4 important novelties compared to the other models of the range:
  • Integrated CPLD with pre-shaping technology. Source synchronization technology via FPGA to correct the I2S signal and eliminate jitter.
  • New FPGA algorithm. The FIFO buffer buffers the data before output, and the output is re-encoded by the FPGA. The Coaxial output can thus support streams up to PCM 384kHz and DSD DoP128.
  • Use of Crystek CCHD-957 femtosecond oscillators with constant-temperature system and ultra-low noise super-capacitor power supply technology. Allows to significantly improve the stability of the clock signal.
  • All circuits adopt synchronous clock design, and the USB clock is synthesized by a PLL derived from the femtosecond clock.
The SU-6's power supply circuitry is particularly neat, using super-capacitors and 6 LDO low noise, fast response. The digital audio circuitry and clock system use independent LDOs to ensure a clean signal.
Product typeDigital interface
Input1x USB-B 2.0
Outputs1x SPDIF Coaxial
1x SPDIF BNC
1x SPDIF Optical Toslink
1x AES/EBU
1x I2S RJ45
2x I2S HDMI LVDS
1x MCLK/WCK
FPGAXilinx
USB ChipXMOS XU208
ClocksCrystek CCHD-957 Femtosecond
Supported sampling ratesI2S : PCM up to 32bit 384kHz, Native DSD up to DSD512
SPDIF & AES/EBU : PCM up to 24bit 384kHz, DSD up to DSD128 (DoP)
Optical Toslink : PCM up to 24bit 192kHz, DSD64 (DoP)
WCLK : PCM up to 768kHz
CompatibilityWindows XP, 7, 8, 10 (driver needed)
MacOS 10.6 and later versions
Linux with UAC2 Android 4.2 kernel and later versions (OTG support)
SPDIF Output level (Coaxial / BNC)550mV
SPDIF Output impedance (Coaxial / BNC)75Ω
AES/EBU Output level3.3V
AES/EBU Output impedance110Ω
WCLK Output levelTTL
WCLK Output impedance75Ω
I2S LVDS Signal via HDMIMCLK, BCLK, LRCLK, SDATA
PIN13-16 : DSD_ON
PIN18 : Weak power output (< 20mA)
PIN1-3 and PIN 7-9 : Adjustable phase via switch
I2S Signal via RJ45CMOS Signal (5V)
I2S Signal settingSwitch 1-4 = PIN13-16 HDMI
Switch ON = Signal DSD_ON
Clock settingSwitch 5-6 = Configuration of the clock output
Switch 5 = O : MCLK Output / Switch 5 = ON : WCK Output
Switch 6 = O : MCLK 22.5792MHz - 24.576MHz / Switch 6 = ON : MCLK 45.1584MHz - 49.152MHz
DSD Channels setting (I2S)Switch 7 = independent setting of left and right channels in DSD
BCLK Sequence setting (I2S)Switch 8 = O : PIN4 = BCLK+, PIN6 = BCLK-
LRCLK Sequence setting (I2S)Switch 9 = O : PIN7 = LRCLK+, PIN9 = LRCLK-
DATA Sequence setting (I2S)Switch 10 = O : PIN1 = DATA+, PIN3 = DATA-
Dimensions233 x 185.6 x 58.4mm
Weight1.6kg
Package1x Singxer SU-6
1x USB Cable
1x Power supply
OutputI2S LVDS via HDMI
OutputBNC
OutputI2S via RJ45
OutputOptical Toslink
OutputCoaxial SPDIF
OutputAES/EBU
Max sampling rate384kHz
Interface chipXMOS XCore U208
5 reviews
Used the SU-6 to connect my Topping D90III Sabre over I2S rather than USB and to my ears this provides a real and very nice improvement in the sound. I did not have to fiddle with dipswitches to get the I2S connection to work. This was a pleasant surprise, both PCM and DSD work out of the box using a standard HDMI cable. Audiophnics delivered the device quickly as always.
This review has been posted for SINGXER SU-6 Digital Interface I2S USB XMOS XU208 32bit 384kHz DSD512
Un réel bon en avant
En remplacement d'une Hecate en sortie d'un Streamer USBridge.
Les 1ères écoutes ne sont pas très riches, mais passé quelques heures tout change.
J'ai nettement gagné sur tout les aspects de la scène sonore, l'image 3D est métamorphosé, tout a plus de matière, plus précis, plus juste, la scène s'est agrandie et je découvre plus de détails, de plus la gestion de la dynamique est bien meilleur.
L'ajout de cette interface au prix non négligeable dans mon système, m'a apporté un réel gain, je suis plutôt très satisfait :-)
indispensable
ce DDC permet de passer de l'usb au I2s et vous permet d'obtenir un rendu sonore exceptionnel a partir d'un portable . les drivers asio fonctionne sans problème (W11) +Jriver32;
Indispensable…
Pour qui souhaite utiliser la sortie usb de son ordinateur. Le résultat dépasse de loin les petites interfaces usb/coax.
Best DDC under 4 digit figures
One of the best DDC's measured by ASR, this one use a femto clock usually found in very high end gear and also have configurable switches for I2s to try any DAC with I2s. Highly recommended! Very fast delivery and excellent handling by Audiophonics!
The Singxer SU-6 is a next-generation digital interface that delivers excellent audio performance through a high-end component-based design. These...
