SINGXER UIP-1 PRO Isolator USB 2.0 480Mbps
The Singxer UIP-1 Pro is a small, high speed (480Mbps), low noise (20µs) USB 2.0 isolator with a 2kvRMS isolation voltage. It also supports USB 1.0 and 1.1 and works simply by plug and play. In addition, it is equipped with ESD protection up to 15000V IEC.
By buying this product you get 27 loyalty points
Reference : 17803
279,00 €tax incl.
232,50 € tax excl.
SINGXER UIP-1 PRO
USB Isolator 480Mbps
SINGXER UIP-1 PRO Isolateur USB 2.0 480 Mbps
The Singxer UIP-1 Pro is a small, high speed (480Mbps), low noise (20µs) USB 2.0 isolator with a 2kvRMS isolation voltage. It also supports USB 1.0 and 1.1 and works simply by plug and play. In addition, it is equipped with ESD protection up to 15000V IEC (air-gap discharge). It is equipped with a USB-B input operating at 5V and a USB-A output with a maximum output current of 1V. The power supply connector is a Jack DC 5.5/2.1mm and accepts 6V to 9V DC voltages (7.5V recommended).
Product typeUSB isolator
Input1* USB-B 2.0
Output1* USB-A 2.0
Supported USB standards1.0
1.1
2.0
Max bandwidth480Mpbs
Output current1V
Isolation voltage2kV RMS
Output noise20µV
Plug and play
Dimensions112*72*26mm
Gross weight0.45kg
Net weight0.2kg
Package1* Singxer UIP-1 Pro
1* Male USB-A to male USB-B cable
1x Power adapter
OutputUSB
Max sampling rateNC
Interface chipNC
The Singxer UIP-1 Pro is a small, high speed (480Mbps), low noise (20µs) USB 2.0 isolator with a 2kvRMS isolation voltage. It also...
