SMSL PO100 Digital Interface USB-C to Coaxial / Optical XMOS 24bit 192kHz DoP64 Silver
The SMSL PO100 is a high performance digital interface based on a XMOS chip. The input is USB-C and the output is Coaxial or Optical Toslink. It supports streams up to PCM 24bit 192kHz and DoP64. An SMSL CK-02 clock allows a considerable reduction of jitter for a precise and detailed reproduction.
Reference : 16327
42,90 €tax incl.
35,75 € tax excl.
SMSL PO100
SMSL PO100 Interface Numérique USB-C vers Coaxial / Optique XMOS 24bit 192kHz DoP64
Product typeDigital interface
Inputs1x USB-C
Outputs1x Coaxial
1x OPtical Toslink
USB InterfaceXMOS
Transmission modeAsynchronous
Supported sampling ratesPCM up to 24bit 192kHz
DoP64
Clock circuitSMSL CK-02
Supply voltage5V 1A
Dimensions45 x 50 x 13mm
Weight75g
ColorSilver
OutputOptical Toslink
OutputCoaxial SPDIF
Max sampling rate192kHz
ColorSilver
Interface chipXMOS
The SMSL PO100 is a high performance digital interface based on a XMOS chip. The input is USB-C and the output is Coaxial or Optical Toslink. It...
