SMSL PO100AK USB Interface XMOS XU316 DAC AK4493S 32bit 768kHz DSD512 MQA
The SMSL PO100AK is an extremely powerful and incredibly compact USB interface with integrated DAC. Despite its small size, the PO100AK is based on an architecture using high quality components to ensure a faithful and precise sound reproduction. It also offers a complete connectivity to answer most of the connection needs, with USB-C as input and coaxial, optical and stereo RCA as output.
3.0 / 5
Reference : 17035
105,00 €tax incl.
87,50 € tax excl.
SMSL PO100AK
SMSL PO100AK Interface USB XMOS XU316 DAC AK4493S 32bit 768kHz DSD512 MQA
USB XMOS XU316 Interface
The USB-C input of the PO100AK is associated with a third generation XMOS XU316 high-end USB interface. This one, in addition to allowing a transparent sound reproduction, ensures the support of high resolution audio streams up to PCM 32bit 768kHz and DSD512.
AKM AK4493S DAC
The PO100AK, providing an analog output in stereo RCA format, embeds a digital / analog conversion stage using an AKM AK4493S DAC chip. The latter guarantees a detailed and clear sound thanks to excellent performances and in particular a very low distortion level measured at only 0.00015%.
MQA Decoder
The SMSL PO100AK is able to decode MQA (Master Quality Authenticated) audio files. These files allow to enjoy a sound as close as possible to the original studio recording.
Product typeUSB Interface
DAC chipAKM AK4493S
USB interface chipXMOS XU316
Input1* USB-C
Outputs1* Stereo RCA output
1* Coaxial
1* Optical Toslink
USB transmission modeAsynchronous
USB compatibilityWindows 7/8/8.1/10/11
Mac OSX 10.6 and later
Linux
Android
iOS
RCA output level2Vrms
THD+N (No-Weighting)0.00015% (116dB)
Dynamic range121dB
SNR121dB
Supported sampling ratesPCM upp to 32bit 768kHz
Native DSD up to DSD512
DSD DoP up to  DSD64
Jitter75ps
general
Supply voltage5V 200mA via USB-C
Dimensions (W*D*H)80*60*13mm
Weight75g
Housing materialAluminum
Input
  • USB
Output
  • Coaxial SPDIF
  • Optical Toslink
  • RCA
Max sampling rate
  • 768kHz
  • DSD512
  • MQA
Color
  • Black
Interface chip
  • XMOS XU316
As a dac
The first impression is that it has a serious problem with the stereo cross talk;huge difference between left and right and generally not the warm sound you would expect from an asynchronus usb dac.Also do not use the included cable as it makes the problem worst.
This review has been posted for SMSL PO100AK USB Interface XMOS XU316 DAC AK4493S 32bit 768kHz DSD512 MQA
The SMSL PO100AK is an extremely powerful and incredibly compact USB interface with integrated DAC. Despite its small size, the PO100AK is based on...
