SMSL X-USB Digital Interface XMOS DSD USB vers Coaxial / Optique / I2S HDMI
Reference : 9725
79,90 €tax incl.
66,58 € tax excl.
The X-USB interface is based on the now famous XMOS allowing you to have a high-end digital output in S / PDIF Coaxial and Optical with an Asynchronous USB management.
Limited to 24bits 192khz via the Coaxial output, this interface allows DIYers to recover the format DSD 64/128 in I2S via the HDMI connector (in this case this interface supports the 384kHz).
Note that the HDMI output of this unit is not standard (see Pin Out).
Characteristics :
  • Displaying the sampling rate on OLED
  • I2S / DSD direct output on HDMI connector
  • Asynchronous USB 2.0 via XMOS
  • Outputs: Coaxial S / PDIF, Optical and I2S on HDMI (32bit 384kHz)
  • DSD on HDMI: DSD 64 (2.8224MHz, 3.072M), DSD 128 (5.6448M, 6.144MHz)
  • PCM to HDMI: up to 32bit 384kHz
  • S / PDIF Coaxial / Optical: PCM up to 24 bit, 44.1, 48, 88.2, 96, 176.4 and 192 (kHz)
  • THD + N: <0.00002%
  • Dynamic range:> 140dB
  • Signal Noise Ratio:> 140dB
  • 2 high precision clock
  • Ultra low jitter
  • USB powered
  • Comes with a USB cable
  • Weight: 480g
  • Windows compatible (driver required), Mac OS, iOS and Android
Download
Driver SMSL 2018 V4.47
Windows Driver (newest version)
Download (2.79M)
