Toslink/Coaxial to Toslink/Coaxial Optical SPDIF Converter Adapter
This little converter is very practical, allowing you to transform a Toslink optical SPDIF audio signal into a coaxial one, and vice versa. It supports Dolby, DTS, AAC and PCM technologies as well as streams up to 192kHz sampling rate. It also incorporates noise reduction technology for clean sound reproduction.
Reference : 15796
17,90 €tax incl.
14,92 € tax excl.
Convertisseur Optique Toslink vers Coaxial Réversible
Product typeSPDIF Converter
Inputs1x Optical Toslink
1x Coaxial
Outputs1x Optical Toslink
1x Coaxial
Supported technologiesDolby, DTS, AAC, PCM...
Supported sampling ratesPCM up to 192kHz
Supply voltage5VDC
Dimensions50 x 49 x 20mm
Package1x SPDIF Converter
1x USB Power cable
OutputCoaxial SPDIF
OutputOptical Toslink
Max sampling rate192kHz
Interface chipNC
9 reviews
Great
Works great, good value for the price.
This review has been posted for Toslink/Coaxial to Toslink/Coaxial Optical SPDIF Converter Adapter
Très utile
C’est tout à fait l’adaptateur dont j’avais besoin.
Great
Works like a charm right out of the box. Easy setup. Only bad thing is the power LED, which is a bit too bright for my taste, but still this is a great product.
Fait le job
Je n'ai pas testé toutes les configurations mais il a marché dès que je l'ai branché sur mon lecteur BluRay Sony qui n'a qu'une sortie coax.
Parfait
Fonctionne parfaitement entre une vieille TV qui sort en coaxial et une entrée spdif sur un WiiM pro plus.
This little converter is very practical, allowing you to transform a Toslink optical SPDIF audio signal into a coaxial one, and vice versa. It...
