.. with babyface pro, need to upgrade the cable that comes with
USB Audio Isolator 32bit 768kHz DSD512
The Topping HS02 is a high performance USB isolator with maximum compatibility to enjoy a cleaner signal on many devices. Its fully isolated design means that it will not introduce new interference if an auxiliary power supply is used and the audio signal is perfectly isolated from any ground loop. The HS02 features dual input and output connectivity: USB-B and USB-C on the input side, USB-A and USB-C on the output side. On each side, a switch allows to select the desired input and output. The isolator also supports high sampling rates, up to PCM 32bit 768kHz and DSD512.
HS02
HS01
Connectors
Two inputs
Two outputs
One input
One output
Auxiliary power isolation
Yes
No
Audio signal isolation voltage
> 1500KVrms
> 1000KVrms
Delay
0.073µs
0.29µs
Product type | USB Isolator |
Inputs | 1* USB-B 1* USB-C |
Outputs | 1* USB-A 1* USB-C |
Supported samplinf rates | PCM up to 32bit 768kHz Native DSD up to DSD512 |
Audio signal isolation voltage | > 1500KVrms |
Delay | 0.073µs |
Suplpy voltage | 5VDC |
Dimensions | 59*38*18mm |
Color | Black |
Package | 1* Topping HS02 1* USB cable |
Average votes 4.8 / 5 5 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
ALEXANDROS M.
Eric G.
Tobie H.
Volodymyr S.
Arnas K.
