TOPPING PROFESSIONAL E2X2 USB Audio Interface White
With the E2x2, Topping offers an excellent audio interface designed for musicians and audio professionals. This excellent interface offers a very high level of performance for perfectly transparent recording and playback.
Reference : 19376
159,00 €tax incl.
132,50 € tax excl.
Topping E2x2 Audio Interface USB 2 In 2 Out 24bit 192kHz White
Topping E2x2 : Front view
With the E2x2, Topping offers an excellent audio interface designed for musicians and audio professionals. This great interface offers a very high level of performance for perfectly transparent recording and playback.
Topping E2x2: Key features
Topping E2x2: Microphone preamplifier module
Topping E2x2: Ultra-linear microphone preamplifier module
The Topping E2x2 is equipped with an ultra-linear microphone preamplifier module developed by the brand, with an input noise of just -130.5dBu. Even at its maximum volume level, the E2x2 can maintain a very low noise floor, ensuring that every detail of your recording is perfectly captured. This ultra-linear architecture ensures that the audio signal is transmitted with sufficient precision for a perfectly clear and transparent recording.
Topping E2x2 : Phantom power supply
Equipped with 48V phantom power and a switch to activate or deactivate phantom power, the Topping E2x2 is perfectly compatible with condenser and dynamic microphones.
Topping E2x2 : Use in recording studios
Topping E2x2: Low-noise voltage module
Topping's unique LNRD module provides a stable reference power level for the AD/DA converter chip, unleashing the chip's full potential for high-purity audio transmission.
Topping E2x2 : Mesures de plage dynamique et THD+N
Topping E2x2: High-performance headphone amplifier
With a noise floor of just 0.9uVrms and an output impedance of 1Ω, the Topping E2x2's NFCA-LE headphone amplifier module enables the use of high-sensitivity headphones without distortion and noise.
The Topping E2x2 offers two gain settings, high gain up to +17dBu and output power of 2x580mW at 32Ω. The combination of this high gain and significant output power means that the Topping E2x2 can easily accompany professional headphones with high impedance, up to 600Ω.
Topping E2x2 : Multiple gain levels
Topping E2x2: zero-latency monitoring
Zero-latency design lets you monitor audio effects in real time during recording or mixing, for enhanced productivity.
Topping E2x2: Analog volume control and wide dynamic range
The volume knobs for the line and headphone outputs use an analog potentiometer, offering excellent precision for easy control of sound level.
Topping E2x2: Independent mixers
Equipped with three 8-channel input mixers, the E2x2 allows easy adjustment and control of audio effects. What's more, its 6 DAW channels and 4 LoopBack channels are designed to adapt to different recording, mixing and playback needs.
Download Topping Professionnal Control Center software
Topping E2x2: independent mixers
Topping E2x2: High audio resolution
The Topping E2x2 adopts an excellent USB XMOS interface, compatible with Windows, Mac, iOS and Android operating systems in particular. It supports high-resolution audio streams for recording and playback, up to PCM 24bit 192kHz.
Topping E2x2 : Interface USB XMOS
Topping E2x2: Two USB-C ports
Topping E2x2 : Dual USB-C ports
The Topping E2x2 uses USB-C connectivity for data transmission and power supply. We recommend connecting the auxiliary power connector if the E2x2 is used in conjunction with a desktop computer, or if 48V phantom power is required, to avoid interference. An external power supply is also recommended when the sound card is used with a smartphone.
Topping E2x2: Aluminum frame
The Topping E2x2's components are protected by a sturdy, durable aluminum-alloy chassis, sober and modern.
Topping E2x2: Connection diagram
Topping E2x2 : Dimensions
Topping E2x2: Dimension diagram
Topping E2x2 : Package
Topping Professional audio interface comparison
E1x2 OTGE2x2E4x4 Pre
OTG interfaceYesNoNo
Power supplyUSB-CUSB-CUSB-C
Interface typeUSB 2.0USB 2.0USB 2.0
MonitoringYes (adjustable mix ratio)Yes (adjustable mix ratio)Yes (adjustable mix ratio)
Input level indicator 1 set of LED2 set of LED4 set of LED
Output level indicator2 set of LED2 set of LED4 set of LED
Module preamp microUltra-linéaireUltra-linéaireUltra-linéaire
Headphone ampNFCA-LENFCA-LENFCA-LE
Supported sampling ratesUSB-C : PCM up to 24bit 192kHz
OTG : PCM up to 24bit 48kHz
PCM up to 24bit 192kHzPCM up to 24bit 192kHz
Software controlYesYesYes
Supported OSMac, Windows, iOS, AndroidMac, Windows, iOS, AndroidMac, Windows, iOS, Android
Power buttonYesYesYes
Weight415g530g830g
Mix channels434
DAW channels868
Loopback channels646
Product typeAudio interface
USB protocolUSB 2.0
Microphon input2x XLR / 6.35mm jack combo connectors
Instrument inputs2x XLR / 6.35mm jack combo connectors
Line outputs2x Jack 6.35mm
Headphone output1x Jack 6.35mm
Direct zero-latency monitoringYes (with mix button)
Input VumeterYes (2x8 LED indicators)
Output VumeterYes (2x8 LED indicators)
Microphone preamp modulesUltra-linear
Headphone amplifier modulesNFCA-LE
Supported sampling ratesPCM up to 24bit 192kHz
Software controlYes (Topping Professional Control)
DAW channels6x
MICROPHONE INPUT MEASUREMENTS (@ 24bit 96kHz)
Equivalent input noise-130.5dBu @ A-wt, 150Ω
THD+N-110dB (0.0003%) @ A-wt
Dynamic range115dB @ A-wt
SNR115dB
Crosstalk-140dB @ 1kHz
Frequency response20Hz - 40kHz (±0.2dB)
Max input level8.6dBu
Input impedance1.5kΩ
Available gain58dB + 20dB (20db digital gain)
Phantom power48V
XLR connector
LINE INPUT MEASUREMENTS (@ 24bit 96kHz)
THD+N-107dB (0.00045%) @ A-wt
SNR115dB
Frequency response20Hz - 40kHz (±0.1dB)
Max input level23.9dBu
Input impedance6kΩ
ConnectorsJack 6.35mm TRS
Instrument inputs measurements (@ 24bit 96kHz)
THD+N-108dB (0.0004%) @ A-wt
SNR115dB
Frequency response20Hz - 40kHz (±0.3dB)
Max input level14.8dBu
Input impedance1MΩ
ConnectorsJack 6.35mm TS
Line outputs measurements (@ 24bit 96kHz)
THD+N-100dB (0.001%) @ A-wt
Analog dynamic range127dB @ A-wt, -40dB attenuation
SNR115dB @ A-wt
Crosstalk-128dB @ 1kHz
Max input level14dBu
Noise1.8uVrms @ A-wt
Output impedance100Ω
ConnectorsBalanced Jack 6.35mm TRS
Headphone output measurements (@ 24bit 96kHz)
Analog dynamic range132dB @ A-wt, -40dB attenuation
SNR115dB @ A-wt
Crosstalk-120dB @ 1kHz
Max input level0dBu @ Gain = L
17dBu @ Gain = H
Noise1uVrms @ A-wt
Output impedance1Ω
ConnectorJack 6.35mm TRS stereo
Headphone output power2x580W @ 32Ω, THD+N < 1%
2x380W @ 64Ω, THD+N < 1%
2x198W @ 150Ω, THD+N < 1%
2x105W @ 300Ω, THD+N < 1%
2x55W @ 600Ω, THD+N < 1%
Power supply5VDC 0.8A via USB-C
Dimensions18.7 x 12.9 x 5cm
Weight530g
ColorWhite
InputJack 6.35mm
InputXLR
OutputJack 6.35mm
OutputJack 4.4mm
Max sampling rate192kHz
ColorWhite
Interface chipXMOS XU308
TOPPING PROFESSIONAL E2X2 Audio Interface USB 2 In 2 Out 24bit 192kHz White
With the E2x2, Topping offers an excellent audio interface designed for musicians and audio professionals. This excellent interface offers a very...
