TOPPING U90 Digital Interface USB to I2S LVDS AES SPDIF Accusilicon 32bit 768kHz DSD512 Silver
20%
Topping unveils with its U90 a powerful digital interface, allowing to take advantage of a wide range of outputs, while supporting high resolution audio streams and embedding an optimized architecture to maintain the integrity of the original signal.
Reduced price!
Reference : 15807
Limited time offer:
599,00 €tax incl.
-20%
479,20 €tax incl.
399,33 € tax excl.
Last items in stock !
Shipping date: 22-01-2025.
Topping U90
Digital interface USB to I2S LVDS AES SPDIF Accusilicon 32bit 768kHz DSD512 Silver
Interface Numérique USB vers I2S LVDS AES SPDIF Accusilicon 32bit 768kHz DSD512 Argent
The input is simply done on USB-B connector. The U90, is also not stingy as for its outputs. There is in fact an I2S LVDs output on HDMI connector, two coaxial outputs, two AES outputs and two optical outputs. Enough to satisfy the great majority of the current uses for this type of device.
Full I2S compatibility
In order to ensure a perfect compatibility with different brands, having an I2S pinout that can vary, the U90 is equipped with four switches allowing to modify this pinout.
Ultra Low Jitter & USB Isolation
The U90 uses a pair of Accusilicon femtosecond oscillators for its clock signal, combined with an Altera MAX II CPLD. This design allows perfect synchronization and management of the clock signals for extremely efficient jitter suppression. In addition, the USB input is isolated to eliminate noise generated by a ground loop.
Trigger 12V
The rear panel of the U90 also has a 12V trigger output. When used with other devices that have this input, the U90 can automatically control the on/off of the system it is integrated in.
Product typeDigital interface
Input1x USB
Outputs1x I2S LVDS (HDMI)
2x AES/EBU
2x Optical Toslink
2x Coaxial
1x Trigger 12V
Supported sampling ratesI2S LVDS : PCM up to 32bit 768kHz, Native DSD up to DSD512, DSD DoP up to DSD256
AES, Optical, Coaxial : PCM up to 24bit 192khz, DSD DoP up to DSD64
Supply voltage100-240VAC 50/60Hz
Housing materialAluminum
Dimensions222 x 160 x 45mm
ColorSilver
Package1x Topping U90
1x Power cable
1x USB Cable
OutputAES/EBU
OutputOptical Toslink
OutputCoaxial SPDIF
OutputI2S LVDS via HDMI
Max sampling rateDSD512
Max sampling rate768kHz
ColorSilver
Interface chipNC
Topping unveils with its U90 a powerful digital interface, allowing to take advantage of a wide range of outputs, while supporting high resolution...
