USB to SPDIF Interface PCM2704 OTG 16bit 48kHz Silver
This low cost USB to SPDIF interface allows an efficient conversion of a signal from a micro USB input to SPDIF on a coaxial or optical Toslink output. It also provides a Jack 3.5mm headphone output and has its own volume control.
Reference : 17533
19,90 €tax incl.
16,58 € tax excl.
Interface USB vers SPDIF PCM2704 OTG 16bit 48kHz Argent
This low cost USB to SPDIF interface allows an efficient conversion of a signal from a micro USB input to SPDIF on a coaxial or optical Toslink output. It also provides a Jack 3.5mm headphone output and has its own volume control (3.5mm output only). The interface uses a PCM2704 conversion chip supporting PCM audio streams up to 16bit 48kHz.
Product typeUSB to SPDIF interface
Input1* Micro USB
Outputs1* Coaxial
1* Optical Toslink
1* Jack 3.5mm headphone output
Interface chipPCM2704
Supported sampling ratesPCM up to 16bit 48kHz
Dimensions55*120*21mm
ColorSilver
OutputOptical Toslink
OutputCoaxial SPDIF
OutputJack 3.5mm
Max sampling rate48kHz
ColorSilver
This low cost USB to SPDIF interface allows an efficient conversion of a signal from a micro USB input to SPDIF on a coaxial or optical Toslink...
