This interface based on the now famous XMOS allows to have digital outputs of high level in SPDIF coaxial and optical with an Asynchronous management of the USB.
High-end version of our interfaces, this model is composed of 3 TCXO high precision gold-plated.
Limited to 24bits 192khz on its outputs, this interface allows the DIYers to recover the I2S format via the I2S connector on the PCB (in this case this interface supports the 384 khz).
Recognized without drivers in Mac-os and linux this one requires a Windows Driver
This model has the possibility of being powered by Jack DC via an external power supply (switch down) or can be powered by USB (switch up).
STARTERS | |
USB | USB-B x1 |
EXITS | |
| I2S | on PCB |
| Coaxial | sPDIF |
| Toslink | Optical x1 |
Features:
- Case 100% Aluminum
- Compatible with Raspyfi, Volumio, Picoreplayer
- Jitter: 4.6 ps
- TCXO Gold plated x3
- Coaxial / Optical: From 44.1K 48K 88.2k 96K 176.4kHz 192K up to 24 / 192K
- I2S: Up to 32bit / 384K
- Power Supply: USB / External via DC Jack 2.1mm (7 to 9V)
- Dimensions: 68 x 33 x 88mm
- Supplied without USB cable
- Color: Titanium
- Weight: 185 g
[Img-11771-left-thickbox_default]
[Img-11772-left-thickbox_default]
