FURUTECH CF-DIN (R) Phono DIN Connector 5 poles Rhodium plated Ø11mm
By buying this product you get 51 loyalty points
Reference : 10404
179,00 €tax incl.
149,17 € tax excl.
Shipping date: 24-04-2025.
Furutech has designed and developed this 5-pin DIN phono connector to be welded, with Rhodium plated contacts of very high quality.
Phosphor bronze conductor treated with the proprietary antimagnetic method FURUTECH Alpha α.
It is the result of uncompromising technical design and robustness and will fit precisely on your vinyl turntable.
Specifications:
  • Phosphor bronze-plated rhodium treated Alpha
  • PTFE Insulation
  • Insulating body Fluoropolymer
  • Carbon coating
  • Welding
  • Overall Length: 40.2mm
  • Overall Width: 14.2mm
  • Acceptable cable diameter: 11mm
  • Weight: 0.035kg / unit
  • Sold individually
Max cable diameter (mm)11.0
Mounting typeTo weld
ConnecticFemale
Contacts number5
Max panel thickness (mm)N/A
ConnectorDIN
