FURUTECH FP-DIN (L) Phono DIN Connector angled 5 poles Ø10mm
By buying this product you get 36 loyalty points
Reference : 10412
129,00 €tax incl.
107,50 € tax excl.
Shipping date: 24-04-2025.
Furutech has designed and developed this 5-pin DIN 90 ° phono connector to weld of very high quality.
Phosphor bronze conductor treated with the proprietary antimagnetic method <strong>FURUTECH Alpha α.
It is the result of uncompromising technical design and robustness and will adapt precisely and discreetly to your vinyl turntable.
Specifications:
  • Alpha Treated Phosphor Bronze Conductor
  • Insulating body Fluoropolymer
  • Welding
  • Overall Length: 45mm
  • Overall Width: 19mm
  • Height: 33.4mm
  • Acceptable Cable Diameter: 10mm
  • Weight: 0.03kg / unit
  • Sold individually
Max cable diameter (mm)10.0
Mounting typeTo weld
ConnecticFemale
Contacts number5
Max panel thickness (mm)N/A
ConnectorDIN
