FURUTECH FP-DIN Phono DIN Connector 5 Poles Ø10mm
With the FP-DIN, Furutech offers a very high quality 5-pin DIN solderable connector. This includes contacts made of Copper Alloy (Bronze Phosphorus) treated using the proprietary Furutech α Alpha antimagnetic process.
By buying this product you get 36 loyalty points
Reference : 10411
125,00 €tax incl.
104,17 € tax excl.
Furutech FP-DIN
furutech FP-DIN Connecteur DIN Phono 5 broches Ø10mm
With the FP-DIN, Furutech offers a very high quality 5-pin DIN solderable connector. This includes contacts made of Copper Alloy (Bronze Phosphorus) treated using the proprietary Furutech α Alpha antimagnetic process. The FP-DIN is the result of uncompromising technical design and robustness and will fit precisely on your turntable.
Product typeDIN Connector
Number of contacts5
Contacts materialPhosphorous Bronze
Insulation materialFluoropolymere
Connexion typeTo solder
Total length54mm
Max diameterØ12.7mm
PTFE part diameter (contacts support)Ø10.1mm
Max cable diameterØ10mm
Weight30g
ColorSilver
Max cable diameter (mm)10.0
Mounting typeTo weld
ConnecticFemale
Contacts number5
Max panel thickness (mm)N/A
ConnectorDIN
With the FP-DIN, Furutech offers a very high quality 5-pin DIN solderable connector. This includes contacts made of Copper Alloy (Bronze...
