VIBORG ND05G NAIM 5 Pins DIN Connector Silver / Rhodium Plated Copper Ø9mm
The Viborg ND05R is a beautifully crafted 5-pole DIN connector, designed with pure copper contacts with triple OFC copper plating, silver and rhodium, offering both excellent conductivity and durability. The connector body is made of brass and the insulation is PTFE. The connector accepts cable diameters up to 9mm.
Reference : 16295
44,90 €tax incl.
37,42 € tax excl.
Shipping date: 07-01-2025.
Viborg ND05R
Viborg ND05R Connecteur DIN 5 pôles Cuivre Plaqué Argent / rhodium Ø9mm
The Viborg ND05G is a beautifully crafted 5-pole DIN connector, designed with pure copper contacts with triple OFC copper plating, silver and rhodium, offering both excellent conductivity and durability. The connector body is made of brass and the insulation is PTFE. The connector accepts cable diameters up to 9mm. This type of connector is notably used by certain Naim devices or in the case of MIDI connections.
Viborg ND05R Connecteur DIN 5 pôles cuivre plaqué argent / rhodium Ø9mm
Product type5 poles DIN connector
Contacts materialPure copper
Contacts platingOFC Copper
Silver
Rhodium
Shell materialBrass
InsulationPTFE
Max cable diameterØ9mm
Mounting typeTo solder
Total dimensions48 x 15.5mm
Max cable diameter (mm)9.0
Mounting typeTo weld
ConnecticMale
Contacts number5
Max panel thickness (mm)N/A
ConnectorDIN
The Viborg ND05R is a beautifully crafted 5-pole DIN connector, designed with pure copper contacts with triple OFC copper plating, silver and...
