AKM AK4495EQ DAC Module Board I2S 32bit 384khz 2x L7805CV Regulators
This AKM AK4495EQ module will give you the opportunity to upgrade your DIY creations to enjoy ever higher sound quality. This will allow you to link, via the I2S, the USB interface of your choice or even a source selector module to complete your audio system.
Reference : 11966
89,00 €tax incl.
74,17 € tax excl.
DAC AK4495EQ
DAC Module Board  I2S 32bit 384khz L7805CV / LM317 / LM337 Regulators
Module DAC I2S 32bit 384kHz Régulateurs L7805CV / LM337 / LM317
A scalable DIY system
Ce module AKM AK4495EQ vous offrira la possibilité de faire évoluer vos créations DIY pour profiter d'une qualité sonore toujours supérieure. Celui-ci vous permettra de lier, via l'I2S, l'interface USB de votre choix ou bien même un module sélecteur de source pour compléter votre système audio :
A DAC that reaches new heights
Equipped with a 32-bit AKM AK4495EQ DAC, you can enjoy the famous Velvet Sound architecture. This allows unexpected sound details to be developed by limiting distortion, in addition to a 32-bit digital filter. Allowing the reading of PCM files up to 384 kHz, it is undeniably a high-end system yet very accessible. In addition, a switch will allow you to access the various Sharp and Slow digital filters.
DAC AK4495EQ
Quality components
The DAC is regulated by a fixed output voltage regulator L7805CV STMICROELECTRONICS as well as a duo LM317T and LM337T. They effectively eliminate single point regulation problems by providing local regulation.
Next to it, a series of low noise amplifiers (LNA AOP) JRC 5534DD allow to process weak signals, while using bipolar technology. These AOPs on removable media are interchangeable by all compatible mono DIP 8 models allowing you to adapt the sound to your desires. Finally, Nichicon capacitors ensure the stability of the signal and its non-deterioration.
The module requires a 2x9V AC transformer and a +/-15V DC linear power supply
The digital filters are adjustable by the red SW switch:
Product typeDAC Module
DAC ChipAKM AK4495EQ
DAC ArchitectureVelvet Sound
THD+N-101dB
SNR123dB
Sampling rateUp to 384kHz
Input1x I2S
Output1x Stereo RCA
Dimensions121.6 x 110.6 x 38.7mm
Fixation holes spacing110 x 100mm
RCA Diameter12.3mm
Max panel thickness6mm
Board diagram
InputI2S
DAC / ADC ChipAK4495SEQ
Max sampling rate384kHz
Channel2 (Stereo)
2 reviews
Très bien
Installé avec reclocker Kali + Raspberry (Picoreplayer)
Parfait !
Précision l'alimentation est 15V - OV - 15V ---- 2 X 9V
This review has been posted for AKM AK4495EQ DAC Module Board I2S 32bit 384khz 2x L7805CV Regulators
Very good DAC implementation
I tested with Raspberry Pi3 + Kali Reclocker and Volumio software and it works great even if there is no suitable driver . DSD files sound perfect!
A nice bonus is that you can change operational amplifiers in the output stage ( I use LME49710 )
This AKM AK4495EQ module will give you the opportunity to upgrade your DIY creations to enjoy ever higher sound quality. This will allow you to...
