AUDIOPHONICS I-SABRE AMP DAC ES9023 / Class D Amplifier 2x30W TPA3118 for Raspberry Pi
Reference : 11800
49,90 €tax incl.
41,58 € tax excl.
This AMP I-SABRE is meant to make your Raspberry Pi a genuine all-in-one multimedia, HIFI-based stereo conversion based on a DAC ESS SABRE ES902324bit 192khz is supported by a class D amplifier of 2x30W.
Thanks to its technology TPA3118 from Texas Instruments, here is the solution to completely transform your Raspberry Pi 3 / Pi 2 into a High Fidelity amplifier.
It forms an "all in one" allowing directly listening on two-way speakers. According to the Linux audio distribution used it will be a perfect companion for the elaboration of less expensive multiroom audio system for example or second HIFI system in an office, a room or a kitchen.
A single external power supply will be required to power this DAC amplifier and the Raspberry Pi 3 or Pi 2. In addition this I-Sabre amplifier has an analog potentiometer volume control.
All these options allow the ease of integration for example in a case modulable to your liking with the potentiometer and the XHP offset for speaker cable provided.
This amplifier can be controlled by our power management power controller
(Attention: the version without voltage regulator must be used)
The I-SABRE AMP is now integrated into our RaspTouch, discover it: AUDIOPHONICS RaspTouch Amp Network Drive / Amplifier ES9023 & TPA3118
Main Features :
  • 100% compatible with Volumio, RuneAudio, Diet Pie, PicorePlayer (Driver: Hifiberry DAC)
  • DAC ESS SABRE ES9023 (24 / 192Khz)
  • Amplifier Class D TI TPA3118 (2x 30W under 8 Ohm)
  • Input voltage: 6V to 26V also powering the Raspberry Pi (Requires external power supply)
  • Recommended power: 24V 4A (not supplied) , Jack DC 5.5 / 2.5mm (+ center)
  • 4-port XHP connector for potentiometer supplied
  • XHP Stereo Speaker Connector
  • GPIO for direct connection to Raspberry Pi 2 and Pi 3
  • Possibility of volume control by adding a potentiometer
  • Outputs: Speakers via terminal blocks XHP 4 PIN
Dimensions and weight:
  • Dimensions: 106x56mm
  • Weight: 102g
the bundle contains:
  • 4 spacers (M3x20mm)
  • 8 screws (M3x6mm) </ Li>
  • A potentiometer with notched pin 6mm with offset wire, 1 nut, a washer
  • An offset cable speaker XHP JST
Jumper liaison I-SABRE AMP
AUDIOPHONICS I-sabre AMP Es9023
Connection diagram of the Audiophonics I-Sabre AMP Es9023
Connection diagram of the Audiophonics I-Sabre AMP Es9023 ATX
Class
  • Class D / T
Input
  • I2S
3 reviews
parfait tout simplement
J'avais testé d'autres marques mais là je touche le Graal. Parfait, sonorité, fonctions, montage. Le tout dans un vieux poste TSF avec un HP large bande, ça envoi...le tout couplé à un bouton poussoir et l'interface ATX associé, avec Max2Play. Squeeze box, Spotify, bluetooth tout est ok ... A souligner l'excellente communication de la société. 3 emails de demandes de renseignements et réponses hyper rapides et précises. Tout ce qu'on aime. Du bon matos et un service exemplaire. Merci à vous, vous avez gagné un client fidèle
This review has been posted for AUDIOPHONICS I-SABRE AMP DAC ES9023 / Class D Amplifier 2x30W TPA3118 for Raspberry Pi
Très bonne solution DAC + Ampli
Facile à monter et à configurer (client Roon avec DietPI). Fonctionne parfaitement, comme je l'espérais, pour alimenter mes vieilles - mais excellentes - enceintes Philips Legend 1. Merci Audiophonics pour la qualité de service (commandé un vendredi et reçu le mardi suivant en Suisse).
Raspberry Pi3, DAC, Ampli, boitier tout en un
DAC et ampli, montage simple, tout est prévu dommage qu'il n'existe pas de boitier avec perçage, mais avec une perceuse et une lime tout va bien
Puissance de l'ampli suffisante pour sonoriser une Chambre, une cuisine, son clair et précis le DAC fait bien son boulot (fichier en FLAC)
Solution complète pour pas trop cher, parfait
